Date codes on cylinder heads??
Old Dec 30, 2011 | 10:49 AM
Redvette_22's Avatar
Redvette_22
Default Date codes on cylinder heads??
Recently I had Patriot heads installed on my 2003 A4 and after a long spell, the shop finally gave me back my "take off" heads. Where are the date codes on the LS1 heads so I can make sure I got "my" good heads back rather then some junk laying around the shop? They were 241 casting on the car and I did get 241's back, but I just have a nagging feeling that they were not from my car, and I know mine were in excellent shape and only changed to get more performance.
Old Dec 30, 2011 | 08:26 PM
tlove32's Avatar
tlove32
241 head is a 241 head. I wouldn't worry about
Old Dec 30, 2011 | 08:31 PM
lucky131969's Avatar
lucky131969
If you can post the full casting number, it can help narrow it down to when there were made.
Old Dec 30, 2011 | 10:27 PM
Redvette_22
If your trying to keep the "original" parts for the future, I think it is something to worry about.
Old Dec 30, 2011 | 10:28 PM
Redvette_22
In my original post I asked where to find the date code numbers, can you tell me if they are cast in like old SBC or are they etched into the head?
Old Dec 30, 2011 | 10:35 PM
lucky131969
In my original post I asked where to find the casing numbers, can you tell me if they are cast in like old SBC or are they etched into the head?
The full casting number is under the valve cover as below:
Casting Number 241
Head: 1997+ LS1 5.7 Litre Passenger Car
Material: Aluminimum
Part Number:
12558806 (1997-98)
12559853 (1999-00)
12564241 (2001-03)
Combustion Chamber Volume: 66.67cc
Compression Ratio: 10.1:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Casting Number 243
Head: 2001 LS6 5.7 Litre Passenger Car
Part Number:
12564243
Combustion Chamber Volume: 64.45cc
Compression Ratio: 10.5:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Casting Number 706
Head: 1999+ LR4 4.8 Litre Truck
1999+ LM4 /LM7 5.3 Litre Truck
Part Number:
12559852
12561706
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Valve Diameter: 1.89 inches
Casting Number 373
Head: 1999-2000 LQ4 6.0 Litre Truck
Material: Cast Iron
Part Number:
12561873
Combustion Chamber Volume: 71.06cc
Casting Number 317
Head: 2001+ LQ4 6.0 Litre Truck
Part Number:
12572035
Compression Ratio: 10:1
Head: GMPP C5R
Part Number:
12480005
Combustion Chamber Volume: 38cc
Compression Ratio:
Intake Port Volume:
Head: GMPP C5R
Part Number:
12480025
Compression Ratio:
Intake Port Volume:
Head: GMPP C5R
Part Number:
12480090
Combustion Chamber Volume: <30cc
Compression Ratio:
Intake Port Volume:
Old Dec 30, 2011 | 11:01 PM
Redvette_22
lucky131969, thanks for that but I'm looking for the "date codes" not the casting numbers. I want to find out if the heads I got back are the ones that "should" be on my production date car. The data stream you listed is quite good and I'm sure will help in many aspects, it's just not what I'm looking for.
Old Dec 31, 2011 | 12:34 AM
lucky131969
You will not find date codes. If you look at the info I provided, the casting numbers fall withing a range of production.
Old Dec 31, 2011 | 09:50 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
is anyone going to mention the dot matrix code on the exhaust side of the head??
also, look on the bottom of the intake runners, sometimes you will see some marks of casting year there
This is a great question!!!
Old Dec 31, 2011 | 11:04 AM
Redvette_22
Steve, this is exactly what I was referring to when I said "etched" in one of my previous posts. This "dot matrix" code, or information must stand for something..but what is it?
Old Dec 31, 2011 | 12:34 PM
lucky131969
I have a set of 241s, and they are devoid of any extra numbers, dates, etc. Now, I did find a pic of early LS1 heads, and the date is clearly stamped.
To Date codes on cylinder heads??
