Does this sound like Piston Slap?
Old Jan 1, 2012 | 01:55 PM
carhopper's Avatar
carhopper
Default Does this sound like Piston Slap?
I've read tons of information on this site and others about piston slap. I believe I have Piston slap, and although GM says it's "within parameters" it still bothers me. I took it to a dealer recently and they said it was normal. Here are my symptoms below, can you guys confirm that I don't have something else wrong. My symptoms are different than what I have read.
1. Cold start I don't hear the slap after pressure builds, usually just about 10 seconds. That I would be OK with.
2. When I accelerate while cold, my car sounds like a diesel under light throttle only. There is a sweet spot in the throttle that isn't rpm dependent, but load dependent.
3. My car didn't always have this problem. When purchased 2 months ago, it wasn't there, but it wasn't cold outside either. I have put on 10,000 miles in the 2 months. Yes I drive it all over the southeast for my job.
4. The piston slap sound goes away completely when the oil temp reaches about 160F.
Old Jan 1, 2012 | 02:28 PM
johnson-rod's Avatar
johnson-rod
Yup. Sounds just like mine. Over 100K and still ticking.
Old Jan 1, 2012 | 02:42 PM
frankb's Avatar
frankb
170,000 and does the same. Just drive it easy to it warms up.
Old Jan 1, 2012 | 02:43 PM
carhopper's Avatar
carhopper
Thanks that's comforting I guess. Maybe I'll put on a louder exhaust so I don't hear it.
Old Jan 1, 2012 | 02:56 PM
johnson-rod
That's what the radio is for...
Old Jan 1, 2012 | 03:31 PM
carhopper's Avatar
carhopper
You know thinking back, it started happening after I changed the oil. Maybe the previous owner had a thicker oil or an additive. I'm going to try 10w40 or 15w50 on my next change which is coming up soon.
Old Jan 1, 2012 | 09:28 PM
johnson-rod
I wouldn't do that if I were you.
Old Jan 1, 2012 | 09:52 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Yep, it sounds like you have piston slap along with most of the LS1 engines out there. The good news, other than being an annoying sound, it doesn't affect durability.
Most vehicles with the noise will peak in level by revving the engine to about 1600 rpm in neutral.
Old Jan 2, 2012 | 03:51 AM
retired cop's Avatar
retired cop
Stick with 5w30 or 10w 30
Old Jan 2, 2012 | 07:28 PM
C5Natie's Avatar
C5Natie
Way too thick. Youll starve the engine at cold temps with oil that thick, making the issue worse. I use 5w30 right now and have had no issues. 10w30 for hot summers only because Im moddified.
Old Jan 2, 2012 | 07:48 PM
LoneStarFRC's Avatar
LoneStarFRC
And no #@&~*$#% additives either.
To Does this sound like Piston Slap?
