Need help with spark plug gapping
Old Jan 2, 2012 | 01:10 AM
jose08m5's Avatar
jose08m5
Default Need help with spark plug gapping
So I'm installing ngk tr-6's in my car but need to know what should they be gapped at?
Thanks,
Jose
Old Jan 2, 2012 | 02:01 AM
Last C5's Avatar
Last C5
Usually .035 is recommended.
Old Jan 2, 2012 | 02:02 AM
Lothar34's Avatar
Lothar34
What does the owner's manual say?
Old Jan 2, 2012 | 02:13 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
what does NGK say the plugs gap to?
I'm using the TR55 gapped at .50
Old Jan 2, 2012 | 02:54 AM
ZeeOSix's Avatar
ZeeOSix
Thanks,
Jose
NGK will show that all their plugs applicable to the LS1/LS6 are gapped to 0.040". Go to their website and look up their application tool.
Originally, the gap was called out by GM at 0.060", but there was a TSB to dealers and all jobbers that changed the gap to 0.040".
That's why every manufacturer of spark plugs will show the gap to be 0.040" regardless if it's a regular plug, iridium plug or platinum plug.
Old Jan 2, 2012 | 11:09 AM
lucky131969's Avatar
lucky131969
Thanks,
Jose
I see from your sig that you are FI. .032-.035 is where you want to be with TR-6s.
Old Jan 2, 2012 | 01:06 PM
printmanjackson
I wonder if that is the reason I see a random misfire. It has only happened a couple of times and both times is when the engine is first fired up cold. I'm going to pull the plugs and change the gap from .55 to .40
Old Jan 2, 2012 | 02:13 PM
jose08m5's Avatar
jose08m5
Thank you guys so much for the help I'm gonna gap the new tr-6's at .40 as I had put some in my car a couple months ago and left them at what they came from from when I opened the box which was .34 and I don't feel my car running right and it also feels like I'm losing power in 3rd gear.
Old Jan 2, 2012 | 04:49 PM
lucky131969
.....as I had put some in my car a couple months ago and left them at what they came from from when I opened the box which was .34 .....
That's good for FI. If anything, you want to go with a smaller gap.......NOT bigger.
To Need help with spark plug gapping
