01 Z06 Not starting
Old Jan 3, 2012 | 04:51 PM
Bman's Avatar
Bman
St. Jude Donor '05
Default 01 Z06 Not starting
Whats up all...
C5 has been sitting for a bit. So I went and got her ready to run but I'm having some probs. Actually it was doing this before I put her in storage. When I turn the key on I will get power to the gauges and some other interior stuff but if I try to start it nothing happens. No power to the radio or windows either.
It was doing this before storage but would always start (eventually).
Now, It started once but I can't get it to do it again. I cleaned the terminals to the fuses under the hood but no luck.
Just thought Id pick your brains before I start ripping things apart..
Old Jan 3, 2012 | 05:13 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Have you replaced the battery or tested to see if you are getting correct voltage?
Old Jan 3, 2012 | 05:15 PM
Lothar34's Avatar
Lothar34
Is the clutch switch working? Are the VATS terminals intact? Does the starter relay work properly?
Old Jan 3, 2012 | 05:20 PM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
Originally Posted by Bman
Whats up all...
Subscribing, going through the same issues. Car sat for a few days and went to start it this morning and it tried to crank and then nothing. Tried to start it again and got a LOW VOLTAGE message, I then ran the codes and P1631 popped up as H C.
Old Jan 3, 2012 | 05:26 PM
1999_TRC's Avatar
1999_TRC
Good questions. What tests should the OP do to make sure those three things are working properly?
Old Jan 3, 2012 | 06:06 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The SECRET to solving a NO CRANK issue is,, you need to use this schematic:
The TDR is the start point!!!
BC
Old Jan 3, 2012 | 06:08 PM
cdkcorvette7's Avatar
cdkcorvette7
EDIT: Schematic above is better than my post...
Last edited by cdkcorvette7; Jan 3, 2012 at 06:10 PM. Reason: Schematic provided above
Old Jan 3, 2012 | 06:39 PM
Bman's Avatar
Bman
St. Jude Donor '05
The problem is/was intermittent and has progressively been getting worse. I just ran across this thread and I bet this is the problem. I'll test my starter switch tomorrow.
http://forums.corvetteforum.com/c5-t...ch-repair.html
you guys rock!
Old Jan 3, 2012 | 06:53 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
HANG ON FOR A MINUTE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!
I will be the FIRST,, to tell you that your IGNITION SWITCH most likely needs work BUT,,,,,,,,,,,,,,,,,,,,,, its "LOW" on the suspect list and most likely NOT,,,,,,,,, your problem!
I would be more towards a defective stater SOLINOID!
Again,,,,,,,,,, the schematic and a VOLT METER will save you TIME & MONEY!
Old Jan 3, 2012 | 08:10 PM
Bman's Avatar
Bman
St. Jude Donor '05
MONEY!
Ok but would a bad starter solinoid throw codes (i get a bunch, service traction control and active handling ect.) and I also do not get power to the radio/windows while she is being finicky..
Old Jan 3, 2012 | 08:11 PM
lucky131969's Avatar
lucky131969
Ok but would a bad starter solinoid throw codes (i get a bunch, service traction control and active handling ect.) and I also do not get power to the radio/windows while she is being finiky..
What codes ??
Old Jan 3, 2012 | 08:15 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What codes ??
Old Jan 3, 2012 | 08:23 PM
lucky131969
I'm in for a P1571.....
Old Jan 3, 2012 | 08:43 PM
Bman's Avatar
Bman
St. Jude Donor '05
What codes ??
Sorry, I stated that wrong. Not codes but "service traction control active handling" and I think "reduced power" messages.
I'll go check.. yes, I feel like an idiot!
Old Jan 3, 2012 | 08:46 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its very easy to have more than ONE ISSUE at once..
Old Jan 3, 2012 | 09:53 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Idiots do not ask questions. They just go to the Stealership and throw money away. You are in good hands here.
Keep asking questions,,,the people on this forum have the answers 9.95 times out of 10!
They have taught me, they will teach you too!
Old Jan 4, 2012 | 12:05 AM
All_Motor_C5LS6
My issue turned out to be a dead cell in my battery. I purchased a new batt and she's purring again.
To 01 Z06 Not starting
Old Jan 4, 2012 | 03:17 PM
Bman's Avatar
Bman
St. Jude Donor '05
My battery was toast and the first thing I replaced.
Today I removed the ignition switch in hopes of a quick fix. I had some bad connections so I repaired and reinstalled. It did not fix my problem although all TC and AH messages are now gone and I can check one problem off the list.
Ok I checked the DIC and I am getting codes:
40 BCM NO COMM.
58 SDM U1000 HC
U1064 HC
60 IPC U1160 HC
U1176 HC
HVAC NO COMM.
So, not really sure where to start. I dont have a workshop manual (anymore). Is the BCM under the passenger side footrest next to the fuse box? does NO COMM indicate a bad BCM or a possible connection problem?
Old Jan 4, 2012 | 03:28 PM
lucky131969
40 BCM NO COMM.
58 SDM U1000 HC
U1064 HC
60 IPC U1160 HC
U1176 HC
HVAC NO COMM.
One common denominator is the feed from the ignition switch to the IPC, BCM, and Airbag. With the key on, I would check for battery voltage at the following fuses in the passenger footwell:
1) minifuse #19
2) minifuse #16
3) minifuse #13
Old Jan 4, 2012 | 03:37 PM
sabastian458's Avatar
sabastian458
I would recomend replacing the starter. From the symtoms you listed, it would seem that the solenoid is failing and the vehicle is still sending power to it instead of the radio ETC.
I had a similar issue combined with a couple of others. The starter fixed my intermitint no start with power inside the car issue.
