2000 vette code 1217
Old Jan 4, 2012 | 12:38 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Default 2000 vette code 1217
Could anyone scan the page of the service manual for code 1217 (relay contact) on a 2000? It seems that no one is repairing them at this time, and I would like to know what the details are of setting the 1217 code.
Old Jan 4, 2012 | 03:21 AM
DeeGee's Avatar
DeeGee
Here you go:
Document ID# 497784
2000 Chevrolet/Geo Corvette
DTC C1217 Pump Motor Relay Contact Circuit Open
Circuit Description
The pump motor is an integral part of the BPMV, while the pump motor relay is integral to the EBCM. The pump motor relay is not engaged during normal system operation. When an ABS/TCS/Active Handling (if equipped with RPO JL4) operation is required, the EBCM activates the pump motor relay and battery power is provided to the pump motor.
Conditions for Setting the DTC
DTC C1217 will set anytime the pump motor relay is commanded on and the pump relay voltage is less than 8 volts, and ignition voltage is greater than 10.5 volts.
Action Taken When the DTC Sets
ABS/TCS/Active Handling (if equipped with RPO JL4) are disabled.
Indicators that turn on:
ABS indicator
Car Icon (TCS indicator)
Messages displayed on the DIC:
Service ABS
Service Traction System
Service Active HNDLG (if equipped with Active Handling RPO JL4)
Conditions for Clearing the DTC
Condition for DTC is no longer present and scan tool clear DTC function is used.
Fifty ignition cycles have passed with no DTCs detected.
Diagnostic Aids
It is very important that a thorough inspection of the wiring and connectors be performed. Failure to carefully and fully inspect wiring and connectors may result in misdiagnosis, causing part replacement with reappearance of the malfunction.
If an intermittent malfunction exists refer to Intermittents and Poor Connections in Wiring Systems.
Test Description
The numbers below refer to step numbers on the diagnostic table.
Checks for a short to ground in CKT 1642.
Checks for an internal short in the BPMV.
Checks for an open in CKT 1642.
Step
Action
Value(s)
Yes
No
1
Was the Diagnostic System Check performed?
Go to Step 2
Go to Diagnostic System Check - ABS
2
Inspect the 40A ABS Maxifuse®, in the Underhood Electrical Center.
Is the fuse OK?
Go to Step 7
Go to Step 3
3
Install a new 40A ABS Maxifuse®.
Cycle the ignition switch from the OFF to ON position, engine off.
Using a scan tool in ABS/TCS or ABS/TCS/Active Handling Special Functions attempt to run the AUTOMATED test.
Recheck the 40A ABS Maxifuse® fuse.
Is the fuse OK?
Go to Step 4
4
Turn the Ignition switch to the OFF position.
Remove the 40A ABS Maxifuse®.
Disconnect the EBCM.
Disconnect the pump motor ground.
Connect the J 39700 Universal Pinout Box using the J 39700-25 cable adapter to the EBCM harness connector only.
Using J 39200 DMM, measure the resistance between terminals E and B of J 39700 .
Is the resistance within the range specified in the value(s) column?
OL (infinite)
Go to Step 5
Go to Step 10
5
Remove the EBCM from the BPMV.
Connect the J 41247 Pinout Box to the BPMV.
Measure the resistance between J 41247 terminal 8 and the BPMV case.
OL (infinite)
Go to Step 9
Go to Step 6
6
Replace the BPMV. Refer to Brake Pressure Modulator Valve (BPMV) Replacement .
Is the replacement complete?
7
Install the fuse if removed.
Using J 39200 DMM, measure the voltage at the 40A ABS Maxifuse® fuse by probing between the fuse test terminals and a good ground.
Is the voltage within the range specified in the value(s) column?
Battery volts
Go to Step 8
Go to Wiring Repairs in Wiring Systems
8
Connect J 39700 Universal Pinout Box using the J 39700-25 cable adaptor to the EBCM harness connector only.
Using J 39200 DMM, measure the voltage at terminal E of J 39700 .
Battery volts
Go to Step 9
Go to Step 11
9
Replace EBCM. Refer to Electronic Brake Control Module (EBCM) Replacement .
10
Repair short to ground in CKT 1642. Refer to Wiring Repairs in Wiring Systems.
Is the repair complete?
11
Repair open in CKT 1642. Refer to Wiring Repairs in Wiring Systems.
Document ID# 497784
Old Jan 4, 2012 | 09:57 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Low battery can cause issues here too although with that circuit open, it needs to be looked at per Dave's recommendations provided already
To 2000 vette code 1217
