Help - 2001 C5 Will Not Start
Old Jan 4, 2012 | 03:26 PM
cvetgo's Avatar
cvetgo
Default Help - 2001 C5 Will Not Start
Last week I had the column lock problem so I purchased the CLB and that took care of the column lock problem. I went to check all the codes and got this message 40 BCM and I can not clear it. The car will not crank, it has a brand new battery. Checked some of the fuses and they are OK. Does anyone know what my problem might be? Starter? BCM Module? Other? I need help please.
Old Jan 4, 2012 | 03:32 PM
lucky131969's Avatar
lucky131969
Please post the entire code.......that does not tell us anything.
Old Jan 4, 2012 | 04:54 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The complete DTC will look like this
40 BCM B2314-H or B1221 - C or B2322 - HC
the BXXXX is the actual code and H & C tell if it is History or Current
Some bathroom reading for you:
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
You can read the DTCs while the engine is running. If you turn the engine OFF and then back ON, that can clear some DTCs that may be important with identifying a problem. One example is a Misfire DTC (p-0300) If the engine is shut down, the DTC will clear.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Old Jan 4, 2012 | 06:08 PM
junk c5's Avatar
junk c5
This might be completely unrelated but here it goes. A buddy of mine just bought a 04 last week. The night he bought it he stopped by on his way home. He shut the car off and while showing me a couple of the issues it had he wiggled the entire steering column (he got the car CHEAP). When he went to start it so he could leave, he turned the key and nothing happened. With a blank look on his face he glanced my way and I seen the "what the **** did I just buy look". I suggested he wiggle the column and it fired right up. The DIC shows a column lock code but he hasn't had much time to diagnose it. Its his winter project car. I'm gonna stay tuned to this thread.
Old Jan 5, 2012 | 09:48 AM
cvetgo's Avatar
cvetgo
Thank both of you for the information. I was not aware of seeing history or current when i do the options and the fuel 4 time manual dia. comes up and I go through the codes. I do have one more question which may not be related to the codes. Last night I made a little set up and ran it in between the headers to the 2 leads on the solonoid and the starter just spins but will not engage. Does this mean the starter has to be replaced?
Old Jan 5, 2012 | 10:07 AM
cvetgo's Avatar
cvetgo
I just went out to the car and did the DTC the way you said and it read
40 BCM B 2723 H C I went to the code link and it said PASS KEY Detection Circuit
Old Jan 5, 2012 | 10:11 AM
lucky131969
40 BCM B 2723 H C Does that help?
Sure does. That code tells you that the BCM is not reading the resistor on your key.....and the starter is diabled. You can try the following:
1) Cleaning the resistor on the key
2) Try your second key
If the above does not resolve the issue, you most likely have a problem with the lock cylinder itself, as it reads the resistor pellet when the key is inserted. Do a search for B2723, plenty of reading on this subject...in most cases....it requires replacement of the lock cylinder.
Old Jan 5, 2012 | 10:48 AM
cvetgo's Avatar
cvetgo
Lucky thank you so much that includes Bill and junk5 also. Thank you Thank you
To Help - 2001 C5 Will Not Start
