Projector light problem 02Z06
Old Jan 4, 2012 | 08:46 PM
02Z06BEN's Avatar
02Z06BEN
Default Projector light problem 02Z06
Hi; I bought and installed spec d projectors. 3 of the 4 lights are working. I verified that it's not the projectors that are the problem rather the harness connection from my Vette. I'm trying to locate/ trace the connection to the harness lead so I can see where the problem may be. Does anyone have a diagram of the harness connections or locations of said leads? I tested the harness and the middle ground (yellow wire) connection is the problem. The inner high beam light is good it's the outer. Any help is greatly appreciated. Ben
Old Jan 5, 2012 | 12:18 PM
cdkcorvette7's Avatar
cdkcorvette7
Partial schematic attached. I'd start by checking fuse 10 in the underhood fuse block...
File Type: pdf
Old Jan 5, 2012 | 01:30 PM
02Z06BEN's Avatar
02Z06BEN
Thank you very much for taking the time and for the daigram!!Ben
Old Jan 5, 2012 | 01:54 PM
cdkcorvette7
To Projector light problem 02Z06
