Does anyone have or can direct me to a site to check the flow numbers on the AFR 205 heads. The AFR site only shows the new 210 chart?
Also, I'm thinking of installing a Texas Speed Torquer V2 or V3 in my C 5 with a Manual Transmissioin. This is a street car only and I wondered if these cams are docile enough for street use?
.200".....140/112
.300".....200/170
.400".....251/203
.500".....281/221
.550".....292/226
.600".....301/230
Both those cams can be tuned to work as streetable drivers
but IIRC the V3 may need the pistons flycut for valve clearance
I'd suggest calling Geoff @ EPS for something like a 226/230
his cams make decent power (especially w/AFRs) and the valve-
train will be quiet.
