Rocker arm nuts
Old Jan 5, 2012 | 09:18 AM
baxsom's Avatar
baxsom
Default Rocker arm nuts
I saw the answer to this somewhere but I cant find it again. When torquing down the rocker arms with the original nuts, do you guys use any sort of anti sieze? motor oil, assembly lube, spit, whatever, or do you torque them dry?
Thanks,
Old Jan 5, 2012 | 09:32 AM
bumble-z's Avatar
bumble-z
Nuts???? not bolts??
GM manual calls for lubricateing the valve rocker arms,push rods w/clean engine oil.
Lubricate the FLANGE of the valve rocker bolts w/clean engine oil.
That is exactly what I did, when I was buttoning up mine from doing a
valve springs change out.
Good luck.
Old Jan 5, 2012 | 01:20 PM
baxsom's Avatar
baxsom
yeah bolts sorry, i was thinking of my 454 which uses nuts, So you just lube the flanges of the bolts and not the threads? wierd
Old Jan 5, 2012 | 01:49 PM
bumble-z's Avatar
bumble-z
That's correct.
Apply clean engine oil to the flange (flat washer like surface) of the rocker arm bolts.
As per GM manual.
Good luck
To Rocker arm nuts
