Dex III vs DexVI
I have also heard of people putting Dexron VI in manual transmissions designed for III, and it burned them up in short time.
I found that they are suppposed to be backward compatible, but I always hesitate to use an upgraded product on an older car that was not designed for it.
DEX III is no longer being made
DEX VI works well in my 2000 C5 6 speed manual with paper backers. 20K+ miles, 2.5 years of use. I’m changing it again next spring with Dextron VI. The transmission works better with Dextron VI than it ever did with Dextron III.
Last time I changed my manual transmission fluid, GM still made, and recommended, using what they call "manual transmission and transfer case fluid", which I suspect is still Dexron III.
Part number 88861800
It’s your car; use what you want where you want. For me, I’ll stick with what was recommended to me by the real experts in the industry on Corvettes. They haven’t let me down on any of their suggestions.
Keep in mind that products documented in the manufactures manuals and services bulletins is your safe bet. GM recommends 88861800, and no, it is NOT Dexron III.
Dexron-III licensing system no longer exists, so, you can buy products that claim to be Dex-III, Dexron-III or any other derivative name, but you have no guarantee it is anything close to the original fluid. If you have doubts, stick with 88861800. For me, I’ll stick with Dexron VI. My car my choice.
AMSOIL's offerings:
Dexron III: AMSOIL Multi-Vehicle ATF (Product Code ATFQT)
Dexron VI: AMSOIL Low Viscosity Universal Automatic Transmission Fluid (ATL) (Product Code ATLQT)
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Your link doesn't work, but I think you meant this one:
GM Dexron VI
I based my 40% difference on the viscosity difference of the Dexron III vs Dexron VI as new out of the bottle for some aftermarket companies as I can't get the actual specs for Dex III and VI. Using the data presented by Sandy Blogs the difference would be 7.5/6.0 = 1.25 or 25% higher.
But, where I disagree with you is that while this graph shows GM Dexron III shearing rapidly down to ~5.0 cSt, which is exactly what the factory fill GM Dexron III did in my 06 CTS-V, after market fluids such as the AMSOIL ATF which use synthetic basestocks do not shear down and stay at the original viscosity of ~ 7.4 cSt. This is why I think many get confused by Dexron III/VI both being products and specs. GM's Dexron III sheared down very rapidly as GM's own data shows. But that does not mean all Dexron III products shear down that fast.
Dex III works just fine and i dont have any issues so you can act like a bag of chips and brag on here but when it works just fine it makes you look like a dumbass.
You really hurt my feelings...
