The C5 lowering bolts are not available through GM separately. They come with new springs.
You can find replacement alternatives through the after market...try HARDBAR USA. You might find some used in the classified section.
You can buy the C6 adjustment bolts separately through GM and the aftermarket, however. They will work, but the rubber bumper pad is thinner so the car may sit lower.
Chances are you're going to need another front spring anyway if the adjustment bolt is rusted. Forcing it may break the threaded insert loose in the composite spring.
Thanks. I will do my best not to ruin the spring. Will it take any heat at all? I have had PB on it for a week.
Mine had been lowered all the way by a previous owner, I was intending to raise it a bit.
I'll tell you, this car grew up in NJ and was clearly driven in the winter on salted roads. What a way to trash a nice car.
Ron
Ron I would think the PB Blaster should help -
You might have to remove the spring out of the Vette and work from the bottom on the foot, since the HEX is busted - perhaps use a Pipe Wrench on the foot pad to back it out -
Make sure you put Anti-Seize on the threads when you put in new ones + a dab of GREASE where the foot sits on the A-Arm it will make future adjustments very, very easy!
I have a set on my old broken spring I was holding onto in case of an emergency - Pm or Email me about them!
I have it double nutted now and still won't budge. I'll let it soak while I clean the control arms and other parts. That will take all the rest of the day, so maybe tomorrow I'll give it a try. Next step will be to cut it off and drill it out. Not much to lose at this point.
And this all started as a head cam swap, I figured I clean the suspension while waiting for engine parts to arrive.......
I had one stuck too. Soaked with PB blaster but was still rounding off the hex. I used the pipe wrench on the round pad trick and it worked for me. Guess I got lucky. This was on a used spring I bought.
Good note about road salt. In a somewhat recent thread, some were of the opinion that winter driving was no big deal. I personally wouldn't even consider it.
With the lower control arm off, it was easy to get at the washer. Here is a photo of the spindle and lower arm cleaned.
Lots of NAPA Aluminum Brightener and elbow grease.
Ron
I'd take a thread chaser (not a thread "tap") to the threaded insert before installing another adjustment bolt...
Suggestion to use a 'chaser' vs. a tap is sage advice. Also, it is recommended to use a grade 8 (or higher) replacement bolt. A grade 8 bolt will have 6 radial arms marked on the head of the bolt.
Do oem (or after market) front C5/C6 adjustment bolts come in grade 8? I know HARDBAR USA uses stainless bolts but the website doesn't give a spec.
Whatever bolts are used, coating them with a light application of anti seize couldn't hurt since there has been corrosion issues.
seabright, I belive you are referring to a rear lowering bolt?
Ron is working on his front adjuster bolts.
I looked in C6 tech and they state the C6 bolt is also not available from GM. Is this true?
Also read that the pads on all of the aftermarket bolts are very poor and fail quickly with the exception of the Hardbar parts which have a delrin pad that causes noise.
Makes a good case for the stock parts.
I'm amazed that GM does not offer these separately. Someone has to make them for GM......
Check with Gene or Patrick at GMPARTSHOUSE to confirm. They'd know and they answer the phone. I was under the impression the C6/Z06 adjustment bolts were available separately through GM.
If I'm incorrect, check with MID AMERICA. They have a set (#624-104 for $45) of four C6/Z06 adjustment bolts for '05-11 cars. Sell two or keep them for spares...
I know there has been a lot of forum response on how to lower your C-5 I am new to the corvettes I just bought my first one last November so i am a complete C-5 rookie I would like to lower my car starting with using the stock bolts. are there any photos on this forum that shows or can someone provide a photo of what these bolts look like and exactly where they are it may be obvious if i pull my wheels but any help prior to me pulling the wheels would be great
