Power Telescoping steering on 2002 coupe
Old Jan 7, 2012 | 09:13 PM
tartaglione88's Avatar
tartaglione88
6th Gear
Default Power Telescoping steering on 2002 coupe
If you have a telescoping steering wheel, should it also have power tilt. Only had the car 4 months and just discovered that either I don't have tilt, or it doesn't work. Telescoping works fine. Thanks, Charlie
Old Jan 7, 2012 | 09:41 PM
65GGvert's Avatar
65GGvert
The tilt is manual. Pull release lever and move where you want it and lock back. It's on 3-5 of the 2003 owner's manual. The 2002 manual may vary, but it's in there.
Old Jan 7, 2012 | 09:45 PM
tartaglione88
6th Gear
Thanks very much
Old Jan 7, 2012 | 09:57 PM
don hall's Avatar
don hall
Section 2, page 42 - 2002 owner's manual
Old Jan 7, 2012 | 10:54 PM
tartaglione88
6th Gear
Guys, I immediately ran out to my 20 degree pole barn and tried the lever back and forth, but did not work. Read the manual which said pull the level towards you. Back out to try again, and this time it worked. It was very stuff but a hard pull got it. Put the car back to it's winter sleep. Thanks for all your replies, Charlie
Old Jan 8, 2012 | 12:09 PM
don hall's Avatar
don hall
Originally Posted by tartaglione88
Guys, I immediately ran out to my 20 degree pole barn ........
Charlie, you might want to 'pipe' a little heat into that pole barn.
To Power Telescoping steering on 2002 coupe
