How much does your Large cam'd C5 shake?
Old Jan 7, 2012 | 10:30 PM
69SSC5's Avatar
69SSC5
Default How much does your Large cam'd C5 shake?
just like the title says, how much does your big cam'd c5 shake? for example when my c5 was stock it didn't shake. Put in a TSP 233/239 cam and all supporting mods and now when your sitting in the driver seat it feels like your sitting on my 2002 tricked out road king (or at least close to that).
Old Jan 7, 2012 | 10:32 PM
Paul 75 L82's Avatar
Paul 75 L82
Yes it is normal. Low cut tube top + hot chick + cam + Z06 = FUN.
Old Jan 7, 2012 | 11:31 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
mine use to shake like crazy and I hated it.
change the motor mounts to the new ones Hinson Motorsports sells and it will stop the shake plus you will feel more torque to the wheels.
I believe they sell stock and lowered heights.
Old Jan 8, 2012 | 12:01 AM
99FRC Newb's Avatar
99FRC Newb
It shook enough that chicks came for a ride for the foot massage (if they had flip flops on)
Old Jan 8, 2012 | 12:18 AM
Johnny Hardcore's Avatar
Johnny Hardcore
Mine shakes well with the 232/236/114...but it was more aggressive with the 228/228/112 I had prior. The 112 lobe bumped nicely. In hind sight I wish I would have went 112 or 111 on this last build. I miss the more aggressive bump.
Old Jan 8, 2012 | 12:45 AM
Lothar34's Avatar
Lothar34
Mine has a 603-612/230-232/112 and doesn't shake a whole lot. I have solid urethane motor mounts.
Old Jan 8, 2012 | 08:21 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
I like the shake, the more the better.
Old Jan 8, 2012 | 11:26 AM
miami993c297's Avatar
miami993c297
With a way LARGER camshaft than yours (StreetSweeper by Ed Curtis) my 346Ci 513rwhp was not shaking at all!!!
Click on the image below and take a look at the iddling video:
Christian
Old Jan 8, 2012 | 11:39 AM
Hauln1203's Avatar
Hauln1203
Mine has a fairly aggressive lope, cam specs: 247/251 656/660 111 LSA. I like it,," I like it alot "
Old Jan 8, 2012 | 11:43 AM
miami993c297
Those are pretty huge numbers for a 346 Ci...
What power is your engine doing with that set-up?
Are you still hydraulic valve-train?
Is it still driveable in the school zones?
Christian
Old Jan 8, 2012 | 12:01 PM
feeder82's Avatar
feeder82
Christian
hauln1203's motor is a 427ci
Old Jan 8, 2012 | 12:04 PM
miami993c297
Then a pretty LITTLE camshaft for that cubic inches!!!!!
Christian
Old Jan 8, 2012 | 12:12 PM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
Whats the compression and fuel and rpm to hit that number ?
that does not seem like 91 octane and 7000 rpms
Old Jan 8, 2012 | 12:47 PM
feeder82's Avatar
feeder82
Christian
Believe me doesnt like a run or sound like a small cam
Old Jan 8, 2012 | 01:40 PM
AU N EGL's Avatar
AU N EGL
also have solid urethane mounts
Little 224 cam, on 112+4 at idle the whole car shakes.
Old Jan 8, 2012 | 05:08 PM
LoneStarFRC's Avatar
LoneStarFRC
Soooo, you braggin' or complainin'?
Old Jan 8, 2012 | 06:36 PM
69SSC5's Avatar
69SSC5
hahaha neither i guess... i was just wondering how everyone else s vette felt
To How much does your Large cam'd C5 shake?
Old Jan 9, 2012 | 03:29 AM
Bluefire's Avatar
Bluefire
I have a 224/230 .585/.588 113 and if you have ***** or a gut, they'll shake at idle.
Old Jan 9, 2012 | 09:48 AM
chevy406's Avatar
chevy406
Idle quality can be somewhat influenced by the tune. For a more aggressive idle lope I like to force Open Loop at idle and then lean it out a little. But there is only so much you can affect with the tune. If you really want the sound and shake, you have to go big with the cam overlap.
Old Jan 9, 2012 | 10:28 AM
AntonioZ06's Avatar
AntonioZ06
I have ECS's Big NA cam and it definitely wobbles. Good fun with female passengers
