part # for valve spring seals
Old Jan 8, 2012 | 08:33 PM
bwill03z's Avatar
bwill03z
Default part # for valve spring seals
Getting ready to order gmpp valve springs and I want to order the gm seals too but I've searched and can't seem to find a part # does anyone have it?
Old Jan 8, 2012 | 08:52 PM
don hall's Avatar
don hall
Is this any help?
http://sdparts.com/details/pac-racing/pac1218
Old Jan 8, 2012 | 09:03 PM
vettenuts's Avatar
vettenuts
With an 03 you need the one piece seal/seat. Best to call one of the supporting vendors or local dealer. I have the part numbers but can't find them however they may have also been superseded.
Old Jan 8, 2012 | 09:05 PM
bwill03z's Avatar
bwill03z
Originally Posted by seabright
Thanks, but that is just the springs. I've already decided to get the GMPP springs, just needing to find the seals now... unless you guys think its ok to use the stock seals?
Old Jan 8, 2012 | 11:20 PM
bwill03z's Avatar
bwill03z
Can someone tell me if this set of Fel-Pro seals will work fine with the GM springs?
http://www.rockauto.com/catalog/rafr...artnum=SS71039
Old Jan 9, 2012 | 05:43 AM
vettenuts's Avatar
vettenuts
If you are using GM beehive valve springs get the GM valve seals. The only time you need to change the type of seal is if you are installing double springs which need the older design.
To part # for valve spring seals
