1997 corvette transmission problem
Old Jan 9, 2012 | 09:36 PM
thegnman's Avatar
thegnman
5th Gear
Default 1997 corvette transmission problem
1997 corvette automatic transmission problem wont go past 50 mph.
Old Jan 9, 2012 | 11:01 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
So, being the first time I've heard of this issue, what exactly is the engine doing when you try to accellerate past 50, such as the RPM just sitting there? Any other information might be very helpful. I don't have an A4 tranny so I'm in the dark other than backyard mechanic questions. Fluid level? Again, not a trans expert...I suggest you contact one such as RPM Transmissions as they are indeed experts.
Old Jan 10, 2012 | 06:28 AM
dougbfresh's Avatar
dougbfresh
Doubt it's the trans. There should be codes but can you feel it shifting into all the gears INCLUDING OD?
Old Jan 10, 2012 | 10:40 AM
dgrant3830's Avatar
dgrant3830
Exactly my thoughts again...does it downshift when you press the accelerator? Pull your codes and see if anything appears there.
Old Jan 10, 2012 | 12:29 PM
BigGun's Avatar
BigGun
Umm...maybe press the accelerator harder.
Need more info.
Old Jan 10, 2012 | 01:16 PM
pat750r's Avatar
pat750r
that happen to me and it was the little plugin for the speed sensor on the diff.. car woulden shift past second gear
Old Jan 10, 2012 | 01:55 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Shift to some other gear other than reverse?
Old Jan 10, 2012 | 03:26 PM
thegnman's Avatar
thegnman
5th Gear
wont go past 50mph and rpm 1500 it shift 1st 2nd gear
Old Jan 10, 2012 | 03:30 PM
dougbfresh's Avatar
dougbfresh
so it only goes into 2nd gear. Did you pull any codes.
Old Jan 10, 2012 | 03:33 PM
thegnman's Avatar
thegnman
5th Gear
only code is po410 secondary air sensor.
To 1997 corvette transmission problem
