You have $6000 what do you buy to go faster?
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
It's a comp cams XER273HR-14 224/230 .581/588 114 LSA. I really like it because it has nice torque down low and it the power just keeps climbing no drop offs or anything. It doesn't really have the big lope sound like the larger cams but you can still tell it has a cam in it.
It added 59 RWHP and 35 RWTQ and I did it when I added the 3.90 gears so that probably effected the numbers a bit. I'll post the dyno sheet later.
Anyway I have the mod bug now and the next step will be high flow heads and intake.. Should be some significant gains. I'll be doing a full write up on everything when it's done.
Hi there, no problem at all! I am indeed on the stock heads. Blackwing intake, and LG Street Headers with xpipe and metal matrix high flow cats going into the NXT Step exhaust system. (borla stinger clone) That is pretty much the full extent of my mods besides the cam and 3.90 gears. When the cam was done the shop also installed the necessary supporting parts for the cam such as dual valve springs, hardened pushrods, etc
Anyway I do have some dyno sheets I'll PM you when I get a chance.
Long-term, every belt driven blower owner I know of has had belt durability issues. The belt also shortens water pump, alternator, and power steering pump life because of the excessive load put on them inorder to drive the blower without slippage.
And, almost every blower package forces the Corvette owner to lay down his radiator resulting in reduced cooling capability.
Brains would say N.A. and gears.
Former Vendor
1 Post
St. Jude Donor '10-'11-'12
IF you want more power and dont want to boost and want the tq and hp low in the rpm band then you have to increase displacement.. Save up another 2500 and we could rebuild what you have to a 383 and give you what your looking for. We can go bigger but it will be more money. Nothing more reliable than good/big cubic inches built correctly and camed accordingly
Like I said this is exactly what I did and I love it. The first time I dropped to 3rd gear on the highway and floored it I felt like I was going into WARP DRIVE! Prepare for lots of fun. The sound the cam makes when going WOT is crazy too... I am guessing that sound is typical of a larger than stock cam?
Anyway the cool part about the 3.90 gears is that not only is your low end much stronger but 5th gear works really well on the highway and 6th gear is actually useable! Yes you can pass people in 6th gear no problem!
Jeff,
Here is what I would recommend:
1) Take your LS6 intake manifold and ship it to TPiS and have them convert it to a 90mm throttle body opening - $ 350
2) Sell or trash you 76mm LS6 throttle body and buy a C6 LS2/LS7 90mm throttle body and the necessary wiring adapter - $350
3) Purchase a set of Total Engine Airflow's GM LS2/LS6 Stage 2 cylinder heads, which come with Titanium retainters, .650" lift PAC valve springs, new keepers, new Ferrea 2.04-inch intake and 1.57-inch exhaust valves, and new valve stem seals - $1,329
4) Purchase a Vinci Hi-Performance Grind #056 camshaft - 216 degree intake duration - 224 degree exhaust duration - .583-inch lift at the valves with 1.8:1 rocker arms - 115 degree lobe separtion angle - $425
5) Purchase a set of Crane's 1.8:1 Gold Race aluminum roller rocker arms - 144759A-19 from Summit Racing - $858
6) Send your differential to RPM Transmissions and have them upgrade it to their Stage 2 level, with a 4.10:1 ring and pinion gear set - $1,795
That totals up to $ 5,109.
You will need to add shipping and installation labor to those costs.
The engine will make approximately 425 RWHP. The cam comes alive at 2,000 rpms and pulls strongly to 6,000 rpms. With the 4.10:1 ring and pinion adding 20% torque at the rear wheels you will be a killer in the low and mid range. This would be a great street package with a smooth idle. Plus, with new cylinder heads your oil consumption will be lowered due to the new stem seals.
The OP sounds like he has talked himself into a SC. I'd go over to C5 Forced Induction and decide between A&A and ECS. Be sure add a set of valve springs when you add the blower. I'd start saving up for a short block next and be sure you have a plan for a fuel system that will keep pace with your build.
#33
SC's add stress to the belt system and majority have lost atleast one belt. Forced Induction is also more prone to detonation from a variety of sources that could result in needing a new shortblock.
#36
Rass Claat Viper
To the OP, one of the reasons why I love the LS motor is the bang for the buck ratio, whether in a snooty C5 or rough and ready Z28. A & A already have the formula figured out with supercharging. Whatever you thought you were going to spend, increase it by 20% and you will be 80% closer to the actual cost. Seriously you don't drive the car that often (weekends and car shows) FI will make it that much more fun when you do decide to get frisky.
#37
#39
A 224/224 or even a 230/232 cam only is hardly pushing and any reliable valve spring should be able to handle it.
#40
If I had $6k to spend on going faster with my stock '03 Z, the 1st thing I'd spend on would be the tires, then the brakes (maybe a set of Ferodo pads), and then a set of coil-overs. Once those were taken care of, and only then, would I think about headers and a tune to my LS6.
