intake manifold swap-problem
Old Jan 14, 2012 | 12:40 AM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
Default intake manifold swap-problem
while removing the intake manifold I have misplaced 2 injector gaskets. this brings a few problems.
1 can I buy these? I have to get manifold gaskets so hopefully the parts store has these.
2 I gently fished one of these out of the head. what if the other ones fell into the head. I've spent a good amount of time looking and cant find any more in there. What will happen if I start the car with a gasket in there?
the good news is that I am putting an LS6 on
Old Jan 14, 2012 | 09:11 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I wouldn't want to start the car if an injector o-ring had fallen in. Yes, it's only rubber and probably wouldn't do any mechanical damage, but it would then wind up being toasted in the cat convertor, which might foul up things. If the manifold is still off the car, I'd get out the shop vac, empty it out, so you could see what it picks up, then vacuum out all 8 cylinders.
Old Jan 14, 2012 | 10:39 AM
C7&7's Avatar
C7&7
I do not think I would start the car either. I also would probably look for the proper O-Ring at a dealership parts dept. Not sure a normal parts store will have anything past a "universal" O-Ring.
I always have left the fuel rails on the intake when pulling an intake. It sounds like you pulled the rails and injectors when the intake was still on the car?
Old Jan 14, 2012 | 01:15 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
Thanks guys. i wll vaccum the engine before i go any further. parts store didnt have the gasket so im going to hit the dealer.
i did take the rails off before removing the intake as per ls1howto.com.
i wont be working on it for a few days but ill post when i know more.
Old Jan 14, 2012 | 02:29 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
If the O-ring fell into the intake track most likely it would be eventually spit out the exhaust--not a super bad deal---If it fell into the oil crankcase--and it ended up in the pan--it should most likely stay there as it won't get past the screen--But if it didn't go to the pan--It could get lodged into a spot where it would plug up the oil flow ( like a lifter--pushrod-PCV system
oil pressure gauge-low pressure safety switch--oil filter---drain back galleys)
Your call--- If it ends up in the exh that would be the best senario--check to see if you can smell burnt rubber when starting-- Good Luck---
Old Jan 14, 2012 | 07:49 PM
bracketshark's Avatar
bracketshark
Hum it might wind up in the exhaust alright along with the intake valve head. It doesn't take much to snap them off. You need to make damn sure it is not in a intake runner. Anywhere else would be better than there. IMO.
Old Jan 15, 2012 | 05:13 PM
tblu92's Avatar
tblu92
Personally i wouldn't worry about a piece of rubber in the valve area---I dropped a NOS brass nozzle in the carb on a race motor and couldn't get it out--I cranked the engine without starting it and found the nozzle mashed into dust in an exhaust port-No problems developed and I did a leakdown test and it was fine----
Old Jan 16, 2012 | 12:19 AM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
Great news. i found the other 2 gaskets! after vacuming the hell out of the head and using compressed air around the rest of the engine i still hadnt found them. i decided to shake the ls1 intake out they fell out. they didnt come out the first time i did it. finding one gasket in the head was enough to make keep looking for the last 2.
glad i found them. the only replacement one i could find was a $100 kit fom the dealer.
thanks for all the help!!!
Old Jan 16, 2012 | 06:58 AM
leadfoot4's Avatar
leadfoot4
Glad to hear that you found them!
With respect to finding replacements, it's not all that hard...assuming of course, you live in a fairly well populated area. The o-rings are nothing more than standard, Viton o-rings. All you need to do is find an industrial supplier that sells gasket material, seals, o-rings, etc. I don't know the correct size off hand, as I haven't bought any for several years. However, there's a "standard" measurement system that categorizes rings by cross-sectional thickness and overall diameter. The proper supplier can sell you them by the car load, and a lot cheaper than the dealer....
(Do a search in your area for a Parker o-ring supplier)
Old Jan 16, 2012 | 09:59 AM
baxsom's Avatar
baxsom
Napa sells O rings or you buy a 15 dollar injector rebuild kit from fuelinjectorconnection.com and replace all of them.
Old Jan 16, 2012 | 10:05 AM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
thanks! I appreciate the info. the GM dealer told me to contact an engine builder so that was going to be my next step. I figured i could get them somewhere...but i was worried i was going to have to buy the kit from GM
its not a standard round O ring. its a rectangular gasket and napa did not have them. either way, all is good
Old Jan 16, 2012 | 09:34 PM
bracketshark
Any hydraulic shop can get them for you if they will.
To intake manifold swap-problem
