Service Selective Ride Code not Found
Old Jan 15, 2012 | 07:05 PM
Speeddemon777's Avatar
Speeddemon777
Default Service Selective Ride Code not Found
Hey Guys,
I have a number of resources that I am using to help me out with this and all of them are coming up empty. I had F45 suspension on my 2000 C5 but I swapped it out about 2months ago for bilstien shocks and simulators. The install was pretty simple and worked great...this is my everyday driver so the car has been drivin alot since then. Now though Im getting a "service selective ride error" pulled the codes and I got C0360HC....I have looked on a number of DIC code websites as well as this forum nothing matching this code. Does anyone have the reference for this code? Thanks.
Old Jan 15, 2012 | 07:13 PM
chaase's Avatar
chaase
St. Jude Donor '12
Suspension position sensor. It might be right rear
Old Jan 15, 2012 | 07:35 PM
Speeddemon777
Thanks for the quick response...im gunna put contact grease on all the connectors see if that helps
Old Jan 15, 2012 | 08:42 PM
65GGvert's Avatar
65GGvert
It may or may not be an issue with your search, but the display shows 0630 and your questions says 0360. Just so you check to see if you're searching the right code due to the two numbers being reversed.
Old Jan 15, 2012 | 08:51 PM
65GGvert's Avatar
65GGvert
C0630 shows this:
DTC C0630 Right Rear Position Sensor Malfunction
Open or high resistance
Old Jan 15, 2012 | 10:36 PM
Speeddemon777
I hate to admit this embarrassing fact but you are correct...i must of had dyslexia when I took my notes...I seriously can not believe this stupid mistake...However, I did find out that the simulator is indeed bad...i cut it open and was able to utilize the plug and make my own simulator with some resistors...I will upload pic soon....thanks guys for pointing out my stupidity
To Service Selective Ride Code not Found
