testing oil pressure sending unit
Old Jan 17, 2012 | 02:09 PM
z06801's Avatar
z06801
Default testing oil pressure sending unit
Is there anyway to test a sending unit? I need to know if mine was functioning when my new motor (433 LS2 with ARE dry sump) spun #1 bearing within 20 miles of driving
Old Jan 17, 2012 | 02:48 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Remove the sensor from the block,, reconnect it to the electrical connector, attach an air line/hose to the sensor fitting and press it up with air to what ever air pressure you want. It should read that pressure on the IPC and gage.
Old Jan 17, 2012 | 03:21 PM
z06801's Avatar
z06801
thanks Bill
To testing oil pressure sending unit
