Upgrading to an 85mm maf
Old Jan 18, 2012 | 03:48 PM
Lifted07Sierra's Avatar
Lifted07Sierra
Default Upgrading to an 85mm maf
I got my 2001+ stock air bridge today and since the 85mm maf have a built in iat what do I do with my current iat whole in the airbridge and wiring?
Old Jan 18, 2012 | 04:22 PM
brandtdavis's Avatar
brandtdavis
Check out this article.
http://www.ls1howto.com/index.php?article=25
Old Jan 18, 2012 | 04:24 PM
Lifted07Sierra
Originally Posted by brandtdavis
Thanks but that doesnt help. That air bridge has no hole where the IAT normally would go. My 2001 that I bought has that hole drilled and tapped and came with a bronze fitting screwed into it.
So would I just plug off that hole with a rubber stopper?
Plus the 3 pin to 5pin harness I bought has a seperate iat cord now too
http://www.ebay.com/itm/250661674605...#ht_500wt_1180
Old Jan 18, 2012 | 08:04 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
personally I think the built-in iat sensor is not good. I found that it was getting heatsoak real bad and was causing my timming to be pulled. I cut the wires and spliced into the harness to relocate my iat sensor to the front of the car away from the engine heat and it solved the problem. I'm also running a Honker CAI and it moved the MAF close to the TB which doesn't help things.
If I were you I would take advantage of the opertunity and re-locate the IAT.
here you can see how close the MAF is to the TB and where I spliced into the harness
the sensor is mounted down in front where air enters the radiator and intake
Old Jan 19, 2012 | 04:08 PM
NemesisC5's Avatar
NemesisC5
Originally Posted by printmanjackson
personally I think the built-in iat sensor is not good. I found that it was getting heatsoak real bad and was causing my timming to be pulled. I cut the wires and tapped into the harness to relocate my iat sensor to the front of the car away from the engine heat and it solved the problem. I'm also running a Honker CAI and it moved the MAF close to the TB which doesn't help things.
If I were you I would take advantage of the opertunity and re-locate the IAT.......
To Upgrading to an 85mm maf
