Car wont start?
Old Jan 18, 2012 | 06:55 PM
98stangt's Avatar
98stangt
Default Car wont start?
It's a 2002 Z. Last week I attempted to start it and nothing happened, the gauges did light up and the speedo and tach did their normal sweep. But that was it. I attempted to strart it several times and after about 5 min it started up. I have driven the car several times since. Well this morning it did not start again with same symptoms. I waited like last time and still nothing. Could this be a problem with the battery or something more technical? Any help is appreciated.
Old Jan 18, 2012 | 07:13 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
There are numerous possibilities...pull your codes using the DIC display and post. Pay attention to the "H" or "C"s with each code.
Old Jan 18, 2012 | 07:24 PM
heavymetals's Avatar
heavymetals
If it happens again, listen for the fuel pump to be running.
It is a lot easier to troubleshoot with two people.
Intermittents are the worst because your odds of getting stuck go up by at least two magnitudes.
Don't know if you are a DIY guy, but I have the special locking ring tool for the pump removal.
At least with a Z you don't have to drop the rear end.
If it doesn't run, try this: take a rubber mallet and tap on the bottom of the fuel tank which is in front of the driver side rear wheel.
I got my buddies to run like that.
Old Jan 18, 2012 | 07:31 PM
VinnyT's Avatar
VinnyT
Did the engine crank or did you just hear a 'click'?
Old Jan 18, 2012 | 07:37 PM
98stangt's Avatar
98stangt
There was no sound from anything. Tried starting it with the garage door closed so that it was quiet. I'm trying to figure how to pull the codes on the DIC.
Old Jan 18, 2012 | 07:45 PM
VinnyT's Avatar
VinnyT
Funny, the other day mine did the same thing. Turned the key, and click. Tried it again and it fired up. Never had that happen before.
Old Jan 18, 2012 | 08:50 PM
98stangt's Avatar
98stangt
Thanks for the helpfull ideas. My (Master Mechanic) wife got it started. She jiggled the keys inside the ignition and it started, which explains why it started last week after the same symptoms. I guess it will go to a dealership to get the ignition checked. Thanks again for the suggestions (8VETTE7 thanks for the site I could not find earlier).
Old Jan 18, 2012 | 09:12 PM
dgrant3830's Avatar
dgrant3830
Bill Curlee has a nice writeup on repairing the ignition switch itself.
Old Jan 19, 2012 | 09:05 AM
red89c4's Avatar
red89c4
ground issues?
Old Jan 21, 2012 | 10:54 PM
joestrazz's Avatar
joestrazz
The same thing happened to me with my 98 coupe with intermittant starting and it turned out to be my starter. While troubleshooting I got under my car and noticed that the battery cable seemed to be loose at the starter but the nut was not loose, the whole stud coming out of the starter was loose, replaced the starter and problem solved.
To Car wont start?
