C5 Mirror Wireing Codes
Old Jan 20, 2012 | 12:56 PM
Gale Banks 80''s Avatar
Gale Banks 80'
Default C5 Mirror Wireing Codes
Hello, I have a Pair of Early C5 mirrors and am wondering what each color Wire dose. They are Early C5 and don't have any Memory and I don't think Heat. There are 6 wires in the loom for each mirror. Thanx...
Old Jan 21, 2012 | 12:35 AM
Gale Banks 80'
OK so I figured out the up down side to side easy enough. I only needed 4 of the 6 Wires. So what are the left over two? In other words do the early C5 have Heat, or Dimming or ??.
So one of the Mirrors is a bit Jerky. I see that a replacement Motor with out Conveinece Package is $100, are they hard to install and do I only need one for each Mirror?? Thanx...
Old Jan 21, 2012 | 03:10 AM
DeeGee's Avatar
DeeGee
Heres the wiring diagram:
Cant help with your other question but the wires are identified. You have 5 inputs and outputs on each mirror from and to the drivers door module. Mirror up and down, mirror left and right, mirror heater. There are 2 additional outputs from the drivers mirror which provide the automatic day/night function on the rearview mirror.
You should be able to identify the other wires by color on the diagram.
Old Feb 5, 2012 | 10:34 AM
Double G's Avatar
Double G
Just what I was looking for.
To C5 Mirror Wireing Codes
