SPEC stage 2 clutch?
Old Jan 21, 2012 | 02:59 PM
69SSC5's Avatar
69SSC5
Default SPEC stage 2 clutch?
i have a 420 RWHP 450 RWTQ C5 that am swapping the clutch on. do you think the spec stage 2 will hold what i need? i plan on tracking the car once or twice with slicks to get the 1/4 mile time after that it will be all street. stage 2 should work right?
also when company's like spec and thus alike rate their clutches for xxx torque does that mean break torque or rear wheel torque?
Old Jan 21, 2012 | 06:36 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
I have a spec stage two on my o2 and I have 495 rwhp and 465 rwtq. I road race and the clutch is fine, not sure about drag racing though. Good luck, as clutch reccomendations and choices seem like a crap shoot, unless you spend big money on a pure racing clutch.
Old Jan 21, 2012 | 09:20 PM
69SSC5's Avatar
69SSC5
thanks for the response. I decided to go with the Spec stage 3 clutch with steel flywheel
Old Jan 22, 2012 | 01:38 PM
cantrelmitl's Avatar
cantrelmitl
St. Jude Donor '10
IMO, I would go with the SPEC 3+, very little difference in price. I would also add a Tick Master while you were at it. It's a little stiffer but the adjustability and speed bleeder just make it sooo much worth the money, especially since you're changing out the clutch already. The 3+ should be fine all the way up to 600RWHP and actually has some good shifting qualities as far as near stock. It has been working fine on my 550+ w/ zero problems. Hope this helps.
Mike C sends
Old Jan 26, 2012 | 10:36 AM
Edward J. Osterman's Avatar
Edward J. Osterman
Default SPEC Stage 2
I used a new Spec Stage 3 to handle 519 at the tires and it hooked up fine but I removed it a few months later due to the lack opf a smooth engagement. It's for sale at a reasonable price. Great product for drag or road racing but I didn't appreciate the engagement characteristics for street.
Ed
Old Jan 26, 2012 | 10:40 AM
Josh@SpartanLSX's Avatar
0Josh@SpartanLSX
Former Vendor
I'd look at the Monster clutches. I've installed 100 of clutches over the years from several manufacturers including Spec, and I feel Monster is offering the best product for the money right now. Their Stage 2 is very smooth and works great on all stock hydraulics.
To SPEC stage 2 clutch?
