Anyone in Omaha with this issue, help me, help you. I have the same issue, if you have an HVAC issue like this I have a shop with solder irons in West Omaha. Send me a PM and you can bring in your unit removed and I'll reflow them for you.
I used the same bulbs in the radio. RadioShack part #272-1154 and it all works great.
I had had burnt out bulbs in both
Thank you, but I was also wondering if there was a fix for the LCD display. I.e. a particular part on the circuit board that could be re-soldered to increase the brightness.
Its not that the resistors are "loose".
Its that the solder connection between the board and the resistor goes bad over time.
Thats why the display "fades" over time.
You just need to add new solder to the resistor points as in my procedure.
Toque
Hey Torque did you use two different cards from two cars to show your proceedure? Cards aren't the same thru out.
Good stuff though!!!
From: Wylie TX --> Less is More, except under the hood !
Thanks !
Yea... I made a note on my web site about the older board that is out there. I did not have a picture of one to put on my site. The same 241 resistors are on the older board as well. They are just in different locations.
Mine faded and then quit. Its been that way for a LONG TIME. I had the center console out for a wide band install and figured,, I will take it to work and fix it.
40 min,, I found two loose resistors on one end and \ soldered ALL the redistors and BINGO! FIXED!!
Feels great to do it yourself and see the results.. If yours is dim or dead,, GET CRACKEN
Bill
Last night was the first time the lights were on and most of the backlighting is out. During the repair all the buttons fell out. I put them all back in. Maybe I broke one of the circuits.
Originally Posted by Ticket Magnet
It was a quick fix.
Any thoughts?
So whats not working now ? The LED display ? The lights for the buttons ?
Had my car only a couple of months now, and my display is non existent. I will be planning on doing this in the next couple of weeks. Thanks in advance!
Nice write up except you only show the board design for the later HVAC units. Hope I did not overlook something. Here is a link that shows where the resistors are for the earlier version. You might want to copy those into yours or provide this link. Mr. Sam
Toque
The lights for the buttons when the headlights are on. The amber indicator lights still work normally. It is the backlighting when the lights are on. Nothing to do with soldering the resistors and the now working HVAC LED display. Just my fumbling of all the buttons and the rubber backing that may have broken something.
