Diff Ratio
Old Jan 22, 2012 | 01:30 PM
hamdog's Avatar
hamdog
Default Diff Ratio
I have a '98 manual. Trying to find the actual ratio. I don't have a glovebox (track car) and the tag on the diff doesn't show the ratio. Any other way to know for sure? Although most manuals are 3:42s I believe some came with the 3:15 as well. So unless you have some concrete info on this, please don't suggest that it is 3:42 by default.
Old Jan 22, 2012 | 01:35 PM
kh400's Avatar
kh400
If you jack up the rear end and use jackstands for safety, please,put the car in neutral and rotate the rear wheels one complete revolution while having someone else observe the driveshaft, noting how many times it goes around. This will give you the rearend ratio. Good luck, remember, JACKSTANDS!!!!!
Old Jan 22, 2012 | 01:39 PM
oh1vette's Avatar
oh1vette
http://forums.corvetteforum.com/c5-g...ear-ratio.html
Old Jan 22, 2012 | 01:40 PM
hamdog's Avatar
hamdog
I have 20" wheels so the ratios will be off.
Old Jan 22, 2012 | 01:42 PM
hamdog's Avatar
hamdog
This post is assumes all manuals are 3:42s and assumes the ratio is on the tag. Neither apply to my post.
Old Jan 22, 2012 | 01:44 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Call a Chevy dealer and ask for parts, give them your vin and they will tell you what gear you have?
Old Jan 22, 2012 | 01:47 PM
hamdog's Avatar
hamdog
Is the ratio listed anywhere else? I'm curious as to why my tag doesn't state the ratio.
Old Jan 22, 2012 | 01:48 PM
hamdog's Avatar
hamdog
Good idea!
Old Jan 22, 2012 | 04:42 PM
DeeGee's Avatar
DeeGee
If its non standard its in your RPO Codes in the glove box:
G90 Axle, Rear, 3.15 Ratio
G92 Axle, Rear, Performance Ratio
GU2 Axle, Rear, 2.73 Ratio
GU6 Axle, Rear, 3.42 Ratio
Old Jan 22, 2012 | 04:58 PM
65GGvert's Avatar
65GGvert
Actually in a 98 it was under the left rear compartment cover. The OP says he doesn't have a glove box, so I'm assuming he doesn't have a compartment cover either.
All manual cars came with a 3:42. The number of revolutions on the tire when jacked up won't change because of tire size, the mark will be the same place on the hub for any size wheel.
Old Jan 22, 2012 | 05:01 PM
Josh@SpartanLSX's Avatar
0Josh@SpartanLSX
Former Vendor
This.
There is no such thing as a manually equipped C5 with a 3.15 gear unless it was installed by a previous owner or a mistake happened in production.
Old Jan 22, 2012 | 05:11 PM
SG Lou's Avatar
SG Lou
How can you observe the drive shaft if it's inside the Torque Tube ?
Old Jan 22, 2012 | 06:05 PM
Dennis Wilson's Avatar
Dennis Wilson
no they wont
Old Jan 22, 2012 | 07:07 PM
hamdog's Avatar
hamdog
I have the compartment cover in garage. I'll ck.
Old Jan 22, 2012 | 08:21 PM
65GGvert's Avatar
65GGvert
If you find the RPO codes on the cover, look for GU6. However, that only tells you what it was built with. Any previous owner could have changed it.
Old Jan 22, 2012 | 09:23 PM
BaadGoat2006's Avatar
BaadGoat2006
my exact thought
Old Jan 22, 2012 | 11:14 PM
hamdog's Avatar
hamdog
GU6 it is! Thanks for the tip. Exactly what I was looking for.
To Diff Ratio
