Anyone wrap their Headers?
Old Jan 22, 2012 | 07:06 PM
TheDEfan's Avatar
TheDEfan
Default Anyone wrap their Headers?
I'm thinking about wraping my Headers to keep down engine compartment temps and to quiet down the valve train noise.
Old Jan 22, 2012 | 07:14 PM
hotwheels57's Avatar
hotwheels57
You might ask your header manufacturer what they think about header wrapping. Most deny warranty if they've been wrapped.
If they're mild steel construction, header wrapping will degrade the steel. I've seen mild steel headers literally crumble, held together by the wrap only.
You will benefit more from a ceramic metallic coating in the long run.
Old Jan 22, 2012 | 08:25 PM
chaase's Avatar
chaase
St. Jude Donor '12
Don't wrap them. They will void your warranty and ruin your headers
Old Jan 22, 2012 | 08:56 PM
TrueBlueCoupe's Avatar
TrueBlueCoupe
I believe most are wrapping the parts they want to protect i.e wires, starter motor
Old Jan 22, 2012 | 09:01 PM
heavymetals's Avatar
heavymetals
I have mine wrapped.
Stainless.
I would do it again, but they smoked like a brush fire when I first ran the motor.
Baked off all the stuff that would smoke.
Old Jan 23, 2012 | 09:56 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
What are all the bennifits of wraping?
Thanks!
Old Jan 23, 2012 | 10:05 PM
heavymetals
Thanks!
Reduces the motor compartment temps.
Insulates heat from melting anything touching the header (which shouldn't be anyway).
Insulates noise.
Old Jan 23, 2012 | 10:19 PM
SacCityCorvette
Supporting Vendor
I herd it also helps complete the burn inside the pipes by making it hotter. Not sure if thats true or not.
Old Jan 26, 2012 | 10:29 AM
Edward J. Osterman's Avatar
Edward J. Osterman
Default Header wrap
I've been running Dynamax long tube headers for 7 years or more unwrapped with no serious engine bay temp issues and a much quicker exhaust "cool down" when the engine is shut off VS stock exhaust. SS headers are great.I've never been a fan of wraping exhaust plumbing.
Ed (C5 ZO6)
Old Jan 26, 2012 | 11:34 AM
chaase's Avatar
chaase
St. Jude Donor '12
I have not heard anything about a burn, but keeping the exhaust gasses hotter means the air will flow out of the exhaust faster.
The problem is that the header wrapping gets wet while being driven in bad weather, while the car is being washed, etc. The wrapping also holds any contaminants in the water like salts and other chemicals. The wrapping doesn't dry easily and your headers end up staying in that moist and potentially chemical laden environment longer than they should.
The moist environment will cause corrosion. Stainless steel is not immune to corrosion. It is just a lot more resistant to it, especially when given ample opportunity to dry.
Old Jan 26, 2012 | 02:18 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Not a smart idea! Get them ceramic coated and be done with it and never look back!
And they look really fugly after awhile!
Old Jan 26, 2012 | 02:47 PM
chaase's Avatar
chaase
St. Jude Donor '12
I wrapped a set of mild steel headers on my old Firebird. There are some other down sides. I found when installing on what was basically an LT4 engine at that time.
It is a royal pita to do. To do it right, you need to pull them from the car and reinstall without damaging/dislodging the wrap. The wrap interfered with the header bolts. I think they interfered with servicing the spark plugs too.
Ceramic coating is what I would do if given the opportunity.
Old Feb 25, 2012 | 11:18 PM
TheDEfan's Avatar
TheDEfan
I was thinking about just wraping the first 4 inchs or so around the plug wire area. I'm having a misfire issue because of heat around the plug wires.
Old Feb 26, 2012 | 02:59 AM
StingrayRebel's Avatar
StingrayRebel
i had my lg's coated by jethot, mainly to keep them looking good but also to help reduce the temps... i had the headers on my old trans am coated by jethot and 3 years later when i sold the car they looked the same as the first day i installed them... it costs about $300 plus shipping to have them coated which may be a little much for some people, especially after spending $1200-$1500 for a header system in some cases, but in the long run i think it's worth it if you have the cash to spend
Old Feb 26, 2012 | 04:00 AM
thechosenone's Avatar
thechosenone
Some of the stuff you guys worry about, lol. Worry about getting into the 8's or a better track time first, then you can start to worry about the small stuff.
Old Feb 26, 2012 | 05:53 AM
baxsom's Avatar
baxsom
then there is something else wrong. i am using GMPP wires surrounded the oem heat shields on my TSP headers and not one is even coming close to touching. A year later and the wires still look new under the shields.
Old Feb 26, 2012 | 06:36 AM
rnelson11's Avatar
rnelson11
Kook sent my headers straight to Jethot and then to me. Do yourself a favor and just have then coated.
To Anyone wrap their Headers?
Old Feb 26, 2012 | 08:32 AM
04blackice's Avatar
04blackice
The problem is that the header wrapping gets wet while being driven in bad weather, while the car is being washed, etc. The wrapping also holds any co§ntaminants in the water like salts and other chemicals. The wrapping doesn't dry easily and your headers end up staying in that moist and potentially chemical laden environment longer than they should.
Now that is something i never thought of or heard of.very good point and helped with my decision.....
Old Feb 26, 2012 | 09:01 AM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
100%
Header wrap should be illegal!
Old Feb 26, 2012 | 10:38 AM
TheDEfan's Avatar
TheDEfan
I swiched from MSD's to the GMPP's with the heat sheilds and heat socks also. It was okay for about a 100 miles and now my missfire is back. I had 3 plugs on the right side of the engine with carbon tracks on the insulators with the MSD's. I have a few of the boots that are a fraction of an inch away from the headers. I'm starting to wonder if I have a lean condition. I have heard that will cause that problem also where the spark will jump from the connector to ground inside the boot, rather than from the electrode to the ground with a lean condition. I'm not real sure about that one.
