Oil filter and oil
Old Jan 22, 2012 | 07:52 PM
Ekul61's Avatar
Ekul61
Default Oil filter and oil
What oil and filter for my 03 purchase. I know this is controversial. I'm guessing mobil1 synthetic but what filter and where to purchase
Old Jan 22, 2012 | 08:23 PM
vettenuts's Avatar
vettenuts
You will get a number of oil recommendations so I won't bother (I don't use Mobil-1 ).
As for the filter, you can't go wrong with AC or WIX.
Old Jan 22, 2012 | 08:34 PM
Jewjenk's Avatar
Jewjenk
The info for the oil is on the oil fill cap and in your manual. Filter, take a pick...........................
Old Jan 22, 2012 | 09:25 PM
BaadGoat2006's Avatar
BaadGoat2006
napa gold or wix filter mobil or amsoil
Old Jan 22, 2012 | 10:07 PM
joestrazz's Avatar
joestrazz
My first oil change is coming up soon and my 98 came with enough mobile 1 to do it but I was told Royal Purple is better.
Old Jan 22, 2012 | 10:12 PM
ALLEGRO's Avatar
ALLEGRO
Any of the fully synthetic oils meeting the GM standard will perform just fine. I recommend the GM filter, but again, most "top shelf" units from the major brands will serve well.
Old Jan 23, 2012 | 02:29 AM
ZeeOSix's Avatar
ZeeOSix
I've ran ACDelco, WIX, NAPA Gold, Amsoil and currently a Purolator PureOne PL14006. All give me the same oil pressure, so all flow well.
PureOne probably has the best filtering efficiency (99.9% @ 20 microns), and they flow very well as can be seen in lab test data. Hard to refute real test data, which is hard to get from the manufactures like shown in the link below.
http://www.bobistheoilguy.com/forums...51#Post1619451
Old Jan 23, 2012 | 02:42 AM
04blackice's Avatar
04blackice
Synthetic and good filter.not fram
Old Jan 23, 2012 | 03:51 AM
joe Villarreal's Avatar
joe Villarreal
ac delco is a good filter
Old Jan 23, 2012 | 07:58 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
do these filters have a bypass valve built in?
I remember on the old school generation engines we use to address this valve on the filter adapter so it wouldn't open so easy and it would filter all the oil.
Old Jan 23, 2012 | 08:52 AM
lucky131969's Avatar
lucky131969
DUMB.
Old Jan 23, 2012 | 12:50 PM
baxsom's Avatar
baxsom
go by the manual.
fill cap is just an advertisement. they could have put pennzoil platinum on the cap just as easily. any GM specd oil. there is a list floating around here.
Old Jan 23, 2012 | 01:51 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
get the oil I use!
Old Jan 23, 2012 | 02:39 PM
jrose7004's Avatar
jrose7004
I use Mobil 1 and the K & N oil filter. I've forgotten the part number for the filter.
Old Jan 23, 2012 | 03:26 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Mobil one is my choice---I'm not a fan of the over advertised Royal Purple its a reatil brand
Also Mobil One now has several choices--be careful here they have
Mobil One Super Synthetic
" " Hi Mileage
" " 4x4 truck
" " Extended Performanace
and 2-3 others---
The super synthetic is the cheapest at around $4.99 QT
The Best is their Extended Perf. at around $8.99 qt
As far as filter go---I have had bad lick with Fram--plugging up and also lowering oil pressure---even when NEW----A test was dome I found online---Not done by a Manufacturer and they found that the Best filters that flowd the best and cleaned the best were :
1. K&N
2. Mobil one
3. A/C Delco
ALSO---For even better protection you can install a filter than is exactly the same but 1" longer---I use this-No ground clearance issues and my caris lowered with LT's- It is the filter used on GM truck 6.0 engines---I think the K&N $ is 2006
Old Jan 23, 2012 | 04:27 PM
cdkcorvette7's Avatar
cdkcorvette7
Originally Posted by 8VETTE7
Any oil that meets Spec GM4718M.
http://lmgtfy.com/?q=site%3Aforums.c...-tech+best+oil
Old Jan 23, 2012 | 07:44 PM
red-in-la's Avatar
red-in-la
ALL your questions are answered here:
http://www.bobistheoilguy.com/forums...Board=6&page=1
And then some you never thought to ask...
To Oil filter and oil
Old Jan 23, 2012 | 08:57 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
For a street driven Vette, my suggestion:
AMSOIL Signature Series 100% Synthetic 5w30 (Product Code ASLQT)
AMSOIL Ea Oil Filter (C5 uses EA15K32)
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jan 24, 2012 | 07:38 PM
Kehraus's Avatar
Kehraus
I use Mobil1 synthetic and Mobile1 oil filters.
They had a special at AutoZone for the 5 1/2 qt size and the filter for $33.
Old Jan 25, 2012 | 11:59 PM
TEXHAWK0's Avatar
TEXHAWK0
Valvoline Synpower and WIX filters
