lowering advice...daily driven-sorta
Old Jan 23, 2012 | 09:41 PM
esemes's Avatar
esemes
Default lowering advice...daily driven-sorta
Hey fellas....
Having my vette lowered tomorrow. It is OEM(possibly more?) Bigfoot tall... have no major areas to climb over, so...
One inch to start? I'm almost four fingers deep on the gap - ouch... the wheel gap ...
Opinions needed!
Old Jan 23, 2012 | 09:50 PM
Kmcoldcars's Avatar
Kmcoldcars
Lower it until it just needs a bit more to look perfect. Then drive it for a week or so to let it settle. Make any adjustments needed, drive it some more, and then when you are happy with it get a 4 wheel alignment. And get Fangs from Sac City or fat daddys to protect the front. Then be careful of steep driveways, speed bumps, and going into parking lots where you go up and then down. Then admire the way it looks and take pictures and post them.
Old Jan 24, 2012 | 04:28 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
Originally Posted by esemes
Hey fellas....
Opinions needed!
Lowering below the maximum recommended by the OEM is a bad idea for several reasons. Conduct a search on the subject, look for post by SOLOFAST. The car will have to be re-aligned after lowering.
Old Jan 24, 2012 | 08:53 AM
Solofast's Avatar
Solofast
Here the step by step in the sticky..
http://forums.corvetteforum.com/1576940245-post92.html
Old Jan 24, 2012 | 09:00 AM
esemes's Avatar
esemes
nice info! thank you!
will follow this and keep the lowering minimal (wanted to anyway)
pics later! (before vs. after)
Old Jan 24, 2012 | 09:45 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Hey fellas....
Opinions needed!
Lower front bolts all the way. Lower rear bolts with 1.5 threads left. Done!
Lowered it in 2004. I still have never aligned my car...tires wear evenly
Old Jan 24, 2012 | 12:59 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Hi Everyone,
Our C5Z is lowered on stock bolts. Fangs are a must have! A nice feature with the Fangs is you don't loose any noticeable ground clearance and that’s very important when your skid plates are already so close to the ground and then you lower them even more! Don't wait till you scrape!
Here is a link to our Fangs.
http://forums.corvetteforum.com/c5-t...eneficial.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old Jan 24, 2012 | 04:57 PM
esemes's Avatar
esemes
Update... had to postpone it till weds..
Big thanks to the guy on the zx10 that blew by me hauling major ***...
That FL state trooper looked pissed....
Old Jan 24, 2012 | 07:32 PM
m6 c5's Avatar
m6 c5
I had that happen to me a little while back with an audi, what made it even better was that he cut me off right when it went down to one lane.
Lowering all the way on stock bolts makes it look a lot better and it really isnt any different driving.
Old Jan 24, 2012 | 07:44 PM
esemes's Avatar
esemes
My shop said 3 threads on the rear and flush up front..
Old Jan 25, 2012 | 06:15 PM
kp1's Avatar
kp1
Great advice. When I bought mine the goof had removed the front bolts and lowered the rear all of the way. It was riding on the bump stops on the shocks and destroyed them and the shocks. Handled like a piece of crap.
Old Jan 25, 2012 | 07:34 PM
esemes's Avatar
esemes
Lowered today... fronts are flush and the rear is 2.5 threads ...
Only gave one finger change in the arches... not settled yet?
Old Jan 25, 2012 | 07:41 PM
bumble-z's Avatar
bumble-z
You need to drive over a few bumps in the road. (kinda hard to find on those nice Fla roads.)
Drive it for a few days to settle.
What are you referring to when you say the fronts are flush? With what?
You wouldn't want to go any lower in the rear. 2-1/2 threads left on the end of the rear bolts, would be the safe way to go with the GM bolts & bushings in the rear.
Old Jan 25, 2012 | 07:43 PM
esemes's Avatar
esemes
Flush to the bushings... drove 20 miles... total Pinellas gridlock at 4.....
Old Jan 25, 2012 | 07:55 PM
bumble-z's Avatar
bumble-z
Are you saying that the front adjusters have all the available threads showing at the top of the front spring & that it's setting as low as it possibly can with the front adjusters?
At any rate, drive the car for a week to let settle.
Good luck.
Old Jan 25, 2012 | 08:18 PM
esemes's Avatar
esemes
Yep.. I think I am... (lowered to they bushings). He might've backed them out.
I didn't pay much attention today....
Old Jan 26, 2012 | 06:46 PM
Pfadt Racing's Avatar
Pfadt Racing
This is why we don't recommend users of our fixed shock products (Johnny O'Connell and Inverted Sport Shocks) lower their cars past what the factory recommends. You can have the greatest shock in the world installed, but with limited suspension travel you are handcuffing the handling potential of the car from the start.
Old Jan 26, 2012 | 06:53 PM
esemes's Avatar
esemes
Okay.....after a day im still liking this height. Ridecomfort is thesame and very minimal scrapes. For a daily traffic light ride, im very happy.
Old Jan 26, 2012 | 08:34 PM
cantrelmitl's Avatar
cantrelmitl
St. Jude Donor '10
Suggest you get some frame savers. They have helped me more than once. In addition, they will also help prevent your rocker panels from messed up.
Mike C
To lowering advice...daily driven-sorta
