C5 Corvette Transmission Mount
Old Jan 25, 2012 | 07:07 PM
AQWIKZ's Avatar
AQWIKZ
Default C5 Corvette Transmission Mount
hey guys I am trying to figure out the wierd thud noise I have everytime I go over a bump. I not sure if its the shocks or rear mount on the rear cradle. should there be any play with the mount? I put the car on ramps the I was able to put the jack under the trans and was able to get alot of movement,but it does not seem to be broken.
Thanks for your help
Old Jan 25, 2012 | 07:30 PM
bumble-z's Avatar
bumble-z
The differential sets on the rear cradle, held by two nuts attached to two studs.
Look to see if those two nuts are loose or possibly the studs are not broken.
Good luck.
Old Jan 25, 2012 | 07:38 PM
AQWIKZ's Avatar
AQWIKZ
all is torqued to proper specs. cant figure this one out
Old Jan 25, 2012 | 07:42 PM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
Shouldn't be a lot of movement...Can you get a look at the diff mount?
Old Jan 25, 2012 | 07:47 PM
AQWIKZ's Avatar
AQWIKZ
its one of those things you wished you had a camera under the car to find the problem. it looks like it moves about a inch or so.
Old Jan 25, 2012 | 07:49 PM
bumble-z's Avatar
bumble-z
Check to see if there is fluid leakage on either rear shocks to detect shock failure.
If you have an aftermarket cat back, it could possibly hitting on something.
Look for areas of scuffing, scratches, or wear marks.
Old Jan 25, 2012 | 07:51 PM
CamminC5's Avatar
CamminC5
Good ideas. If you don't come up with anything there drop the cradle and see if the mount is busted.
Old Jan 26, 2012 | 08:10 AM
rnelson11's Avatar
rnelson11
In a previous post you said you were waiting on the Hinson transmission mount. Did you ever get one?
Old Jan 29, 2012 | 09:51 AM
AQWIKZ's Avatar
AQWIKZ
never got a Hinson mount I am going to replace the shocks next weekend and the drop the cradle to check the mount.
Old Jan 29, 2012 | 10:10 AM
bumble-z's Avatar
bumble-z
Which mount do you have?
Old Jan 29, 2012 | 10:50 AM
AQWIKZ's Avatar
AQWIKZ
stock mount
Old Jan 29, 2012 | 11:36 AM
bumble-z's Avatar
bumble-z
Your probably allready well aware that there are two bolts going upwards from the transaxle bracket into the rear of the differential.
Make for certain that they are not loose or broken
There are of course the two bolts facing downwards from this bracket goiing through the transaxle mount & rear cradle, with nuts on the bottom side of cradle.
Do hope you find the culprit of the noise.
Old Jan 29, 2012 | 11:41 AM
AQWIKZ's Avatar
AQWIKZ
I have checked all mounting points, but I will recheck them,when I checked them nothing was loose and all are torqued down to specs.
Old Jan 29, 2012 | 11:48 AM
bumble-z's Avatar
bumble-z
You spoke of a "thud" noise in your first post.
This isn't a metal to metal clanking?
If the top shock mount bolts are loose this would create a deffinite noise.
Allso the very top side of this mount (you cant see it) where the top of the shock is mounted with a nut, could be loose, causing a noise.
Old Jan 29, 2012 | 12:17 PM
AQWIKZ's Avatar
AQWIKZ
I will check the mount that you talk about I was not aware of that. live and learn I hope thats it. I know the the shock is not loose,so maybe the mount.
Old Jan 29, 2012 | 01:35 PM
bumble-z's Avatar
bumble-z
The nuts for the shock mount plate are factory welded in. (2)
Some times the weld breaks.
Othertimes it could be the bolts come loose from factory shock mount plate .
Old Feb 10, 2012 | 07:11 PM
AQWIKZ's Avatar
AQWIKZ
found the problem, it was the o2 sensor hitting the tunnel plate
To C5 Corvette Transmission Mount
