lean bank code
Old Jan 25, 2012 | 11:32 PM
latenightlarry's Avatar
latenightlarry
Default lean bank code
my 04 z06 engine check light came on, on the way back from a road trip at 75 mph . took it to the dealership and they found a crack in the hose from the maf sender . replaced it and still throwing code indicating lean bank 1 & 2. i have a calloway honker intake and till now no problems . any ideas? the tec said it only happens when the car is driven not at idel like most . anyone with any ideas? thanks larry
Old Jan 26, 2012 | 12:23 AM
latenightlarry
ttt
Old Jan 26, 2012 | 12:32 AM
Speeddemon777's Avatar
Speeddemon777
Sounds like an air leak...generally if a car has the ability to suck in air after the mass air flow sensor this can happen. I would check your air duct and all rubber connectors/hoses. I had this happen on a supercharged truck awhile back ended up being hose that came off the intake manifold after the MAF. Worst case is your MAF sensor is bad. Best of Luck!
Old Jan 26, 2012 | 10:03 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Also check the bridge hose to the maf to insure it hasn't come off on the bottom of it
Old Jan 26, 2012 | 12:42 PM
hotwheels57's Avatar
hotwheels57
After you've completed the recommendations above, you might consider one of these from HALLTECH. The '04 Z06 did not have an MAF screen from the factory...
http://www.halltechsystems.com/Hallt...r_p/hc.125.htm
You're at sea level. If your system is leak free you shouldn't experience lean bank codes.
I'm at 5,200ft altitude. When I first got my car, I installed a "Blackwing" and got intermittent annoying lean codes. I removed it.
I recently installed a "Honker" along with the HALLTECH screen. So far, no lean codes. It might help you as well.
To lean bank code
