Blackwing on 2002 Install Questions
Old May 12, 2002 | 06:57 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Default Blackwing on 2002 Install Questions
I am going to attempt to do this myself, but I haven't found instructions for the 2001/2002 install, only the earlier model that doesn't require the adapter. Can you send me your links to good instructions for the install? I have seen the install here in tech tips, but I'm just looking for other instructions that may be a little more detailed and do include the adapter.
Thanks!
Update: Got the job done in about an hour...really took my time. Very straightforward, and there were some excellent instructions with great pictures on the C5 Forum site. Took all the guesswork out of it for me. Today I put the BW on as well as the CAGS Eliminator. Next is the Corsa Indy exhaust, but I'll pay someone to take care of that for me!
P.S. Got my first official wave yesterday...almost missed it, but returned the wave before he was out of my sight. A great tradition!
[Modified by scirica, 1:32 AM 5/13/2002]
Old May 12, 2002 | 07:00 PM
Patches's Avatar
Patches
Default Re: Blackwing on 2002 Install Questions (scirica)
I installed a BW recently on my 2002. No real difference from the standard instructions except that you use the larger soft coupler instead of the small one. It's very straight-foward.
Old May 12, 2002 | 07:13 PM
BLKBLUR's Avatar
BLKBLUR
What Patches said is correct. Also--there is a rubber gommet thing on the Blackwing, that must be removed from the Blackwing so you can attach it. The 2002's have a larger opening than the earlier models.
I hope you understand what I'm trying to say. Hopefully, someone else will chime in the a more techincal explaination.
Good Luck and enjoy. I really like my Blackwing!!!!!!! :cool:
[Modified by Y2K2C5, 6:14 PM 5/12/2002]
Old May 12, 2002 | 07:43 PM
HOCKEY's Avatar
HOCKEY
Default Re: Blackwing on 2002 Install Questions (Y2K2C5)
I have no clue as far as working on my car for add ons but put mine in less than 25 minutes. Very easy to do.
Old May 12, 2002 | 09:18 PM
AFVETTE's Avatar
AFVETTE
Am I missing something here. Do these things come with instructions? I'm getting ready to order mine and this seems absurd that everytime I see a Blackwing post it's for two things;
1 - Didn't get instructions how do I install or clean it?
2 - Why are folks cleaning these already? A K&N can go over 25K miles before they recommend a cleaning. What is the recommended cleaning mileage for a B/W?
Tom
Old May 13, 2002 | 07:13 AM
vettenuts's Avatar
vettenuts
Default Re: Blackwing on 2002 Install Questions (AFVETTE)
Did you cut the hose on the side of the filter? I have to cut mine in the middle of the curve to get it to stay on.
Old May 13, 2002 | 10:22 AM
wineguy's Avatar
wineguy
Default Re: Blackwing on 2002 Install Questions (vettenuts)
No need to cut the hose.Re-use the fitting from your origional setup,turn it 90 degrees and install in the blackwing.
To Blackwing on 2002 Install Questions
