Upper arm(front one) mounting bolt thread size
Old Jan 27, 2012 | 08:35 AM
always faster's Avatar
always faster
Default Upper arm(front one) mounting bolt thread size
Im about to put my new motor in.When i did the uninstall i saw that the threaded parts in the frame where the upper arm bolts needed some cleaning with a tap.I cant seem to find the correct thread size for those bolts...
So does anyone knows what is the tread size of the 4 bolts that hold the upper arm(front one) ???
Old Jan 27, 2012 | 09:43 AM
bumble-z's Avatar
bumble-z
I've had my bolts out, plenty of times.
If I had one out at this time I would probaly be able to tell you but....
If I were you, I'd take the bolt down to a good auto parts store, such as Nappa, etc & have them find/fit a nut on the bolt & then you would know the tap/chaser size. (Aren't all four bolts the same size?)
Just trying to help.
Good luck.
Old Jan 27, 2012 | 09:48 AM
DIXZ's Avatar
DIXZ
The upper control arm bolts are M10 X 1.5.
Old Jan 27, 2012 | 10:53 AM
always faster
Good luck.
The problem is that the bolt are still on the car.Im trying to take some few detail fix before the install.Thanks
Thanks a lot
To Upper arm(front one) mounting bolt thread size
