Which intake manifold should I get?
Old Jan 27, 2012 | 09:04 PM
00vettebham's Avatar
00vettebham
Default Which intake manifold should I get?
should i get a Fast LSX 102mm intake or a ls6 intake and then have it ported?
Old Jan 27, 2012 | 09:27 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
What does the rest of your motor combination consist of?
You will be wasting your money if you buy a LS6 manifold AND port it.
Old Jan 27, 2012 | 09:34 PM
00vettebham
Currently I have lg pro long tube headers, z06 titanium exhaust, vararam intake, pro torque torque converter.
I just need throttle body, intake manifold, heads, and cam.
Old Jan 27, 2012 | 10:21 PM
mchicia1's Avatar
mchicia1
Get a used fast 90/92 if you can find it, if not get a 102 and cross your fingers it fits ok. An ls6 will certainly leave power on the table if you plan on going heads/cam.
Old Jan 27, 2012 | 11:19 PM
chaase's Avatar
chaase
St. Jude Donor '12
I would just get and use a stock ls6, unless you are trying to suck every last bit of power out of the setup. It is a big cost jump from an ls6 to a fast 102
Old Jan 28, 2012 | 12:29 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
since you have heads and cam I would go for the 102, it woke my torque up everywhere!!!!!
Old Jan 28, 2012 | 11:45 AM
Redvette_22's Avatar
Redvette_22
PM sent
Old Jan 28, 2012 | 12:26 PM
baxsom's Avatar
baxsom
i have seen people post well over 500 hp dyno charts with the ls6 intake here. use the ungodly amount of money the fast 102 and throttle body, not to mention the new fuel rails as well as the pain in the *** factor for install and get a set of good heads.
Old Jan 28, 2012 | 12:52 PM
I brake for nothing's Avatar
I brake for nothing
Do you have before and after dyno results ? Can you post your combo ? I am in the same boat. The 102 seems crazy over priced.
Old Jan 28, 2012 | 02:06 PM
Vicarious.'s Avatar
Vicarious.
what heads & cam are you going with? the fast 102 might be an overkill depending on what you go with.
Old Jan 28, 2012 | 02:19 PM
printmanjackson
I tune mine with HPTuners and haven't had it on a dyno yet.
I pulled the LS6 and stock 85mm TB and went to the LSX 102 and a 90mm LS2 TB. All I can tell you right now is from about 3500 rpm up it's a beast and I can tell I'm getting on the edge of over powering my clutch.
I'm running 243 heads that AI did some mild work on with a custom cam with only .600 lift.
I don't understand why everyone is complaining about price. The intake sells for about the same price as the LSX 92 did. You don't have to buy a top of the line TB either. You can find brand new LS2 tb's for a little over $200 and I would think if you went with either LSX intake you would replace the tb anyway.
I did replace my motor mounts with the urethane and that was one of the best mods I ever did.
Old Jan 28, 2012 | 02:22 PM
I brake for nothing
Thanks for the info.
Don't you have to replace all your fuel rail crap too with the 102 ? What was the total bill on teh swap.
Old Jan 28, 2012 | 02:33 PM
printmanjackson
yes you have to replace the fuelrail because the intake is much taller. I think the fuelrail was @ $160
I do all my own work including tuning so I was only out for the cost of parts. I sold my stock intake and tb so the total cost wasn't too bad.
Old Jan 28, 2012 | 02:40 PM
printmanjackson
here is a forum sponsor that sells this intake at a great price
http://forums.corvetteforum.com/c5-t...ls7-truck.html
you can buy a brand new LS2 TB on the auction site for $277 shipped. It is sold from a GM dealer
Old Jan 28, 2012 | 03:11 PM
I brake for nothing
I guess the stock parts are worth a few points.
Old Jan 29, 2012 | 12:08 PM
I brake for nothing
What are you doing for your heads and cam ?
Old Jan 29, 2012 | 01:02 PM
2MFFZo6's Avatar
2MFFZo6
I did replace my motor mounts with the urethane and that was one of the best mods I ever did.[/QUOTE]
.........ls2 fuel rail
To Which intake manifold should I get?
Old Jan 29, 2012 | 10:43 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
I am agood example---I run almost 600rwhp with a LS-6 intake
and a Shaner throttle body. The only thing a high priced intake
will do --I will lose some low end torque and a $1000.
Old Jan 29, 2012 | 10:48 PM
I brake for nothing
I cant say I buy that.
Old Jan 30, 2012 | 02:56 AM
baxsom's Avatar
baxsom
thank you,
proof positive that unless your next meal is a direct result of whether or not you dial in the quickest time, the 102 may just not be needed.
