73 Radiator Change
Old Jan 28, 2012 | 03:10 PM
gcarpenter's Avatar
gcarpenter
Default 73 Radiator Change
It took taking the radiator loose to get the fan shroud out. Even then, I had to use brute force to pry it out. How on earth do I get it back in with the new radiator in place? There has to be an easier way. I would think the radiator should go in and then the shroud. Help!
Old Jan 28, 2012 | 03:25 PM
Lothar34's Avatar
Lothar34
http://forums.corvetteforum.com/c3-tech-performance-3/
Old Jan 28, 2012 | 04:28 PM
baxsom's Avatar
baxsom
wrong forum but when i did my 72 radiator and shroud i ended up having to take the fan clutch assembly out to get the shroud back in. i ended up putting in an electric fan from a lincoln MKVII and wire it into the head with a thermal switch. then you dont need the shroud.
To 73 Radiator Change
