column lock problems
Old Jan 31, 2012 | 08:16 PM
evolution02's Avatar
evolution02
4th Gear
Default column lock problems
i have a 02 corvette zo6 and yesterday evening when i got into my car to head home from work and i get a "service column lock" message when i turned my car on. my steering wheel is still free to turn but i notice i dont hear the lock engage anymore. i just finished reading the sticky concerning column lock issues and i couldnt find anything about situations when the lock fails in the open position. any ideas as to a remedy for this? or should i take my car to my local dealer to have it checked out?? again...my car is still drivable but id like to have it remedied before it turns to a more dire situation then just a warning on my gauge cluster. any insight would be appreciated. thanks.
Old Jan 31, 2012 | 08:55 PM
Jnape's Avatar
Jnape
So your column still locks? If so I wonder if the Dealer will still do the recall on it for free. I would not want a functioning lock on either of my cars. If you still hear the lock solenoid, you don't have an aftermarket CLB either.
Old Jan 31, 2012 | 09:01 PM
evolution02
4th Gear
actually it doesnt lock at all and i get the message on my dash. its a good thing that it failed in that position (if indeed it has failed) cause shes my daily driver. its more of an annoyance that i see that message when i get in my car.
Old Jan 31, 2012 | 09:04 PM
Jnape's Avatar
Jnape
Just do the CLB. $50 bucks and less than an hour of work. Keep your battery in good shape but as it is your DD you will be fine.
Old Jan 31, 2012 | 09:07 PM
evolution02
4th Gear
ill definately look into that. thanks.
Old Feb 1, 2012 | 06:13 PM
evolution02
4th Gear
yea the column lock always functioned properly until the other evening. i measured the voltage before putting my dads battery tender on it and it was only reading 12.1 volts and was still reading that voltage after a charging stint. went and picked up a battery during my lunch hour and everything is working like a champ. no message on my dash and the column is functioning like normal. thanks for the insight guys. i was hoping this was gonna be an easy fix.
Old Feb 1, 2012 | 09:02 PM
Baldfart's Avatar
Baldfart
I would still get yourself a CLB.
To column lock problems
