Cam info...
Old May 13, 2002 | 07:06 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Cam info...
Ok, if I wanted to just add a cam which one would you recommend and what would be the cost involved doing it myself.
Old May 13, 2002 | 05:34 PM
99 Corvette's Avatar
99 Corvette
Default Re: Cam info... (pewter99)
A4 or MN6? Your best bet would be to talk to a tuner and tell them just what you want and don't want :cheers:
Jerry
Old May 13, 2002 | 05:39 PM
JerryL's Avatar
JerryL
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Cam info... (99 Corvette)
You can get a high quality cam for under $400.00.
Old May 13, 2002 | 06:53 PM
pewter99's Avatar
pewter99
Default Re: Cam info... (JerryL)
If I understand correctly I can do a cam swap and just change the cam and valve springs, etc????
Old May 13, 2002 | 07:22 PM
66ImpalaLT1's Avatar
66ImpalaLT1
The minimum you should do with a cam swap is the cam, springs and pushrods. I changed the cam, springs, retainers, pushrods, asp pulley, timing set and oil pump at the same time.
Eric
Old May 13, 2002 | 09:31 PM
pewter99's Avatar
pewter99
Default Re: Cam info... (66ImpalaLT1)
:D
To Cam info...
