Will my drivetrain blow?
Old Feb 1, 2012 | 11:07 PM
TA Racer's Avatar
TA Racer
Default Will my drivetrain blow?
I have a 99 vette with the following mods:
Vararam, catback, LS7 clutch, hardened output shaft and an ECS brace.
How dangerous would it be to run it at the track with drag radials? I would be launching it at about 2500 rpm, but would be shifting aggressively through the rest of the gears. Assuming I avoid wheel hop, how close would I be to blowing anything on the drivetrain?
Also, what ET could I expect if I run it with the radials?
Old Feb 2, 2012 | 12:12 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The rear-end is the weakest link. You would most likely (but not 100% going to) break an output shaft.
Your tires are the FUSE at the track. If you put a bigger better fuse in the tire slot,, the differential output shaft FUSE will blow! ANY excessive wheel hop will cause that fuse to blow!
Wheel hop is the enemy of drive train reliability! PERIOD!
I have run my 02 ZO6 at the track with out any issues, I run it hard on the street with out drive train issues. I DO prevent wheel hop by tires, launch technique, shocks and care.
NO Issues!
BC
Old Feb 2, 2012 | 08:53 AM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
NO Issues!
BC
Bill; If you continue to leave your "signature" they WILL catch you!!
Old Feb 2, 2012 | 10:20 AM
m6 c5's Avatar
m6 c5
NO Issues!
BC
Whats up with right side mark? Its real light in the center.
Old Feb 2, 2012 | 02:10 PM
TA Racer's Avatar
TA Racer
I did change the weaker of the two output shaft (forgot if it was the left or right). So as long as I manage my wheel hop I should be good to go. I'm a former F-body guy, and their drivetrains were terrible from beginning to end. It's hard for me to believe that swapping out a few parts on a vette will do the trick.
Old Feb 2, 2012 | 03:49 PM
racetchr's Avatar
racetchr
NO Issues!
BC
Old Feb 2, 2012 | 04:42 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
AH, grasshopper,,,, You have very good observation skills.
When I up-graded the rearend with C6 ZO6 parts I found that the bellview spring on that side was broken. That will cause the clutchs on that side to catch and release and make those marks. If you look hard , you will see the mark on the right starts to fade a few feet before the one on the left. The clutches were most likely SMOKING HOT!
Heres a picture of the broken spring:
BAD BAD BAD!!!!!
TA Racer
If you have already installed a hardened output shaft, keep the wheel hop out of the launch and you should be good to go.
Bill
Old Feb 2, 2012 | 05:31 PM
SaberD's Avatar
SaberD
I wouldn't run the stock diff on drag radials.
Old Feb 2, 2012 | 07:49 PM
m6 c5's Avatar
m6 c5
BAD BAD BAD!!!!!
TA Racer
Bill
I figured if it was something like that then it wouldn't have been nice and black on the outsides and would have been like the inside, but I guess it makes sense.
To Will my drivetrain blow?
