brake problem...whats the suspect?
Old Feb 3, 2012 | 03:32 PM
dreww's Avatar
dreww
Default brake problem...whats the suspect?
Only when braking hard, I have a loud and violent vibration from the rear of my c5. I've been told three different things it could be:
Warped rear rotors
pads with uneven wear
the shoes for the e brake
What do you think? I wouldn't say the shoes cause the e brake isn't applied under normal braking. I just need to know the parts to order before putting it in the shop on a lift while I get the parts I need.
Im thinking warped rotors which of course would be new rotors and pads
Old Feb 3, 2012 | 03:43 PM
sean.b's Avatar
sean.b
if its warped rotors, it's taken the pads with it. if it's uneven pads, its probably taken the rotors with it..
i'm not a mechanic, so i cant say for the ebrake, but ive never personally seen/heard of it dragging on hard brakes?
only time ive warped a rotor, it wobbled around on ANY braking, so going with a text based description, i'd say get the pads/rotors.
Warped rear rotors
Old Feb 3, 2012 | 06:38 PM
rodsvet's Avatar
rodsvet
Get it up in the air and check the suspension. Loose shocks, sway bar end link, etc. Without hearing it or seeing it it's hard to say. If you have a warped rotor you should be getting one side or the other to chirp as it grabs and then lets go when hard braking. Just my .02. Be safe, Rod
Old Feb 3, 2012 | 06:50 PM
sean.b's Avatar
sean.b
the fact it only does it on hard braking is the only thing that made me hesitate. that could be something loose.. cus warped is warped, no matter the speed.
Old Feb 3, 2012 | 08:13 PM
jrose7004's Avatar
jrose7004
Sounds like warped rotors to me.
Old Feb 4, 2012 | 12:13 AM
striper's Avatar
striper
Warped rotor to me, too. It only takes one for the whole rear to feel bad. If you need rotors go to www.brakemotive.com. For the price of two, you can get four plus pads, shipped too. I previously had bad rotors and these cleared up my problem and are good quality.
Old Feb 4, 2012 | 08:46 AM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
Simple enough to check for warp with a dial indicator....I'd not order parts without an inspection first.... GL
To brake problem...whats the suspect?
