Car running hot
Old Feb 6, 2012 | 05:18 PM
99vettish's Avatar
99vettish
Default Car running hot
My car is running hot and the temp will get up to 255. I can shut the engine down and within 1 min the temp will go down to 220.. Does this sound like a thermostat problem? The fans are not coming on either... Can some give me some feed back...
Old Feb 6, 2012 | 06:01 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Ok, so did you check the fuses for the fans? Was the HVAC turned on?
Old Feb 6, 2012 | 07:10 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Also what is it doing wile driving then does it go up, down, or stay steady at a stop?
Old Feb 6, 2012 | 08:22 PM
99vettish's Avatar
99vettish
It at 220 then it shoots up to 255 - 260 --- I will check the fuse for the fans..
Old Feb 6, 2012 | 08:47 PM
Paul 75 L82's Avatar
Paul 75 L82
Clean out the fins of the rad and AC condenser with your garden hose or compressed air.
Old Feb 6, 2012 | 09:46 PM
99vettish's Avatar
99vettish
Thanks, I will try this..
Old Feb 6, 2012 | 10:56 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
turn on the AC and see if it comes down
Old Feb 6, 2012 | 11:19 PM
Cherokee Nation's Avatar
Cherokee Nation
How do you get to the rad ? the condenser is in front of it,can only see a small part ot it from under the hood?
Old Feb 6, 2012 | 11:23 PM
cookie7's Avatar
cookie7
Check the 3 fan relays in the engine bay fuse box ;Mine was doing the same thing a week ago;Had a bad relay $7.00 each replaced all three just for fun Problem solved Give that a shot ..Good Luck..Matt
Old Feb 7, 2012 | 04:58 AM
vettenuts's Avatar
vettenuts
Pull the intake tract including the MAF. Then remove the four 10mm screws holding the top plastic radiator support. You will then be able to see between the radiator and the condenser.
Old Feb 7, 2012 | 09:52 AM
Cherokee Nation
Thanks Guy
Old Feb 7, 2012 | 09:54 AM
dgrant3830's Avatar
dgrant3830
I asked the question about the HVAC being turned on for a very specific reason but no answer. If the HVAC is on and the fans start running, then there's no issue with the fuses and probably not the relays.
Old Feb 7, 2012 | 10:00 AM
BIGWILL_88's Avatar
BIGWILL_88
Default This is good to know
So I am just asking, but we can run water on this to get it clean? Can you also use a light brush to clean it and then run the water to get the debris off of it? Thanks, CF Strikes again
Old Feb 7, 2012 | 04:44 PM
99vettish's Avatar
99vettish
The fans come on when the HVAC is on but they don't come on at any other time. Just when the HVAC is on...
Old Feb 7, 2012 | 04:50 PM
99vettish's Avatar
99vettish
Ok..I drove the vette to work today, whithout doing anything but pushing on radiator hoses and the temp stayed under 220... Thermostat sticking????
Old Feb 7, 2012 | 05:02 PM
toddk's Avatar
toddk
Even at 240* with no A/C, they don't come on? The fan temps are tunable, so perhaps you need to have them reset. They should come on in two stages (low/high) at two different temps.
If you just idle it and let it heat up, does the temp plateau or keep climbing? It should go up til the fans kick in, then drop back down and the fans should drop out. Are you saying if you idle it, it will climb to 255 with no fans engaging?
At highway speed did it hang around 190? That is the temp where the thermostat will open & close to keep you right at that temp.
I'm in the middle of a head/cam project and had the luxury of removing the radiator to see what's going on. A couple passes of shopvac (from the front), 100psi compressed air wand (from the rear), and water stream (from the rear) did pretty well. Then a can of the foaming HVAC coil cleaner from Home Depot, and it shines like the sun! I would avoid any brushing, as it can mash the vanes and prevent airflow.
Before:
Foaming cleaner:
After:
Old Feb 7, 2012 | 05:09 PM
dgrant3830's Avatar
dgrant3830
Here is the circuit. Please note that if the fans come on with the HVAC running, then you most likely have debris plugging things up as already mentioned. No need to check fuses, relays and so on.
To Car running hot
Old Feb 7, 2012 | 05:19 PM
99vettish's Avatar
99vettish
The fans never come on until I turn on the AC.... So it sound like the thermostat is ok and something else is the problem...
Old Feb 7, 2012 | 05:20 PM
99vettish's Avatar
99vettish
I checked the fuses and they look ok..
Old Feb 7, 2012 | 05:40 PM
99vettish's Avatar
99vettish
Thanks for the info guys!!!!
