Horn wont work?
Old Feb 9, 2012 | 01:33 AM
a/c man's Avatar
a/c man
Default Horn wont work?
horn was moved after supercharger install wont blow!! pulled horn hooked it to battery it works! checked power at the horn and I'm getting power? bad ground need help anyone ever had this problem?
Old Feb 9, 2012 | 09:11 AM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Check your horn fluid, I had the same problem, was a quart low!
Works great now and no issues!
Sorry Scott, I couldn't help it!
Old Feb 9, 2012 | 03:41 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Could be a bad membrane in the airbag steering wheel. They now sell them for $60 bucks.
Need a few more details on how you checked for power at the horn connector.
Old Feb 9, 2012 | 09:09 PM
a/c man's Avatar
a/c man
its a 10,000 mile car after the A&A it did this it was working at first but very low sound came out so i tested it on the battery and it was loud!! bad ground?
Old Feb 10, 2012 | 07:53 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
It could be a bad ground or low voltage. Did you measure the current to see that you getting 12 V. Those idiot test lights are good making sure that you don't have a broken wire but they don't tell you if you have enough current to power the item at the end.
I had a crazy problem on rear tailight, where I was getting power but not enough to power the signal light. Turned out to be a bad connector but took me forever to trace it down.
Old Feb 10, 2012 | 01:03 PM
a/c man's Avatar
a/c man
sounds like your right I did use a test ligth I will ck for proper voltage no thanks
Old Feb 10, 2012 | 01:13 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Electrical problems suck, hopefully its an easy one to figure out.
To Horn wont work?
