Any problems running without wheel sensors?????
Old May 13, 2002 | 08:28 PM
Maineiac's Avatar
Maineiac
From: Making my carbon footprint as BIG as possible
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06
Default Any problems running without wheel sensors?????
I want to buy some wheels and drag radials....will the car throw a bunch of codes if I don't use wheel sensors? :confused: :confused: Thanks. :seeya
Old May 13, 2002 | 08:33 PM
SilverStar's Avatar
SilverStar
Default Re: Any problems running without wheel sensors????? (Maineiac)
When you start the car you will get an error message on the dic (can't remember the precise wording); one push of reset and it will disappear until you start the car again. Not a problem; I ran without sensors for a year.
If you scroll through your error codes you will get some communication error codes that I attribute to same.
Old May 13, 2002 | 08:38 PM
Reeves's Avatar
Reeves
From: The inmates are running the asylum... San Jose, CA
Default Re: Any problems running without wheel sensors????? (SilverStar)
"Service tire mon. sys." :D
I've been running without sensors since January. The only side effect I've noticed is needing to hit the reset button everytime I start the car.
Old May 13, 2002 | 08:49 PM
Maineiac's Avatar
Maineiac
Default Re: Any problems running without wheel sensors????? (Reeves)
:cool: Thanks guys. :seeya
To Any problems running without wheel sensors?????
