Help steering locked at a shop....
Old Feb 9, 2012 | 04:37 PM
Ole Blaster's Avatar
Ole Blaster
Default Help steering locked at a shop....
hi everyone,,,took my 99 frc to shop, oil change and other stuff,, battery got low and "POW" steering locked!!!!! they were unable to free it so they cut the pin...it now turns but they want to pull the steering wheel to remove the pin but the wheel is stuck on... they messed up 1 puller and almost messed the plate in the steering wheel... any sugestions on what to do ????..Thanks in advance..
Old Feb 9, 2012 | 05:21 PM
Bill Dearborn's Avatar
Bill Dearborn
Get it away from those Dorks as quickly as possible and get it to somebody that knows how to work with the lock. When power is lost like that the lock system sometimes gets out of synch and won't unlock. There are ways to recover without cutting the pin or pulling the steering wheel.
Bill
Old Feb 9, 2012 | 05:32 PM
Ole Blaster
Bill
thanks for reply Bill... but too late,, they cut the pin already,,but cant pull the steering wheel off... A GM mech. is going by to see what he can do tonite...I pray he knows what to do... I'm looking for any fellow CF friends info if possible.. thanks again...
Old Feb 10, 2012 | 08:49 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Taking a wild thought here, wondering if the relay for the Steering Pin lock, cooked when the battery went low. Might send a PM to 8VETTE7 just in case.
Old Feb 10, 2012 | 12:39 PM
Cybermind's Avatar
Cybermind
Personally, I would get my car out of there ASAP before they screw up something else. I would have it flatbeaded to a proper Corvette shop and hope that nothing's been damaged too badly so far.
Old Feb 10, 2012 | 01:36 PM
imavettegirl's Avatar
imavettegirl
another good reason to change you own oil/filter.
Old Feb 10, 2012 | 01:56 PM
Ole Blaster
another good reason to put a 4 sale sign on it...
Old Feb 10, 2012 | 01:57 PM
Ole Blaster
thanks,,, If there was a proper Corvette shop around here it would have been there in the 1st place....
Old Feb 10, 2012 | 02:01 PM
Ole Blaster
Thanks dgrant3830,, this looks like a better avenue,,, I'll shoot 8vette7 a mess. and see if he can help...
Old Feb 10, 2012 | 05:40 PM
k24556's Avatar
k24556
Default Pin?
something doesn't add up. what pin did they cut? If it is the column lock pin, then wouldn't the steering wheel have to be removed to access it?
If they did indeed cut the pin, then they will owe you a new lock motor.
They must really be zeros if they resorted to the hammer and saw to solve a problem like this.
Old Feb 11, 2012 | 08:43 AM
Ole Blaster
yes the pin is cut...the wheel will turn...but the steer. wheel is stuck on and the pullers will not work...he said the only way to remove it is to make cuts and pull on it til it comes off...
Old Feb 11, 2012 | 10:00 AM
Z06supercharged's Avatar
Z06supercharged
I gotta ask...what shop was this? Pep Boys? Firestone? Hyundai dealer?You need to post the name so no one else takes their car there for an "oil change".
Old Feb 11, 2012 | 11:46 AM
Ole Blaster
Originally Posted by 8VETTE7
If the pin is actually cut and you have looked carefully at the pictures in the link I PM'ed you (same as the one above) then you will see that the column will no longer lock. That being said there is NO REASON to remove the wheel. I would get the car put back together, the battery FULLY charged and get the car out of there as fast as possible. The people you have workinkg on the car are professional a$$ holes and not mechanics. First they cut the pin which they never should have done and now they want to cut the steering wheel. WTF Run from them before they destroy the car and/or it is totally unsafe to drive again.
so you would trust it to drive???? if so I'll pick it up Monday ( closed sat & sun.) ????
Old Feb 11, 2012 | 11:47 AM
Ole Blaster
please hold that thought... I'll get back..
Old Feb 11, 2012 | 02:38 PM
Slick Rick's Avatar
Slick Rick
What a bunch of illiterates. Alls they had to do was recharge the battery. Should of unlocked on its own.
Old Feb 11, 2012 | 03:00 PM
imavettegirl
to o.p.: why are all your answers so cryptic?
Old Feb 11, 2012 | 03:35 PM
Ole Blaster
well after 3000 miles, I so far have $3000 plus on repairs,and its in the shop now with more problems,,, loved the car but my nerves are shot, my visa is maxed, unable to get a full nite of sleep and wondering should I take to the dealer and trading it for a simple ride...this has been the worse car I ever owed,, at 56 years old this is saying alot...sorry if I offended you or anyone else here...I hope you can understand.
To Help steering locked at a shop....
Old Feb 11, 2012 | 05:21 PM
bontrager's Avatar
bontrager
Not always. My car has been stored for a couple of months now. I did experience one lock up. Charged the battey, placed the key in the ignition and it unlocked. Every two weeks I place a charger on it to bring the battery to fully capacity. I did this again yesterday, full charge.
Placed the key in the ignition and got the message: remove the key and wait for 10 seconds, which I did.
You guessed it, the wheel locked up again and won't unlock. Even tried to turn the wheel left and right against its stops repeatably and no luck.
It will be towed tomorrow to my Chevy dealer. I do have the column lock bypass part of which I am going to ask them to install once the situation is diagnosed properly. The harness mod/recall was installed by Chevy in 2004.
Old Feb 12, 2012 | 08:09 AM
Jewjenk's Avatar
Jewjenk
When one buys a Vette, one should learn and be able to make repairs by themselves as much as they can. when one takes car to dealer, all they see is a Lamborghini or other exotic car coming in and either don't know exactly how to work on it, charge excessive repair fees or both. Personally I would have had the car towed to the house and then posted to the forum if the problem or/and fix was not evident.
Old Feb 12, 2012 | 08:15 AM
rclinton's Avatar
rclinton
Veteran: Marine Corps
I'm right up the road in Jacksonville (Richlands) I am retired and willing to give you a hand to get your ride up and running . Drop me a line. Bob
