Shocks Squeaking?
Old Feb 10, 2012 | 09:43 AM
ryrob's Avatar
ryrob
Default Shocks Squeaking?
I drove to work this morning in 33* weather and was alarmed at noise coming from my front end. It seemed like every bump or turn I made, I could hear a squeaking sound coming from the front end. I drove around the parking lot at work over a bunch of speed bumps and every time the suspension would go up and down I would hear the sound.
Is this squeaking coming from the shocks and is this temporary, maybe caused by the cold weather? Or are there underlying issues here? Definitely would be embarrassed if someone were in the car with me....sounds like an old beater going over bumps!
Old Feb 10, 2012 | 10:20 AM
johnson-rod's Avatar
johnson-rod
Anti sway bar bushings are a major cause of squeakings and groans. Easy to lube. Check these first.
Old Feb 10, 2012 | 10:21 AM
87SAM's Avatar
87SAM
This link has a lot of good ideas on the possible source of the noise. Plus it has a funny video!
http://forums.corvetteforum.com/c5-t...ave-video.html
Old Feb 10, 2012 | 10:34 AM
Piper250's Avatar
Piper250
Its probably your control arm bushings, replace them with new polly busings.
I just went through this excercise and did the sway bars, shocks, bushings, tie rod ends and ball joints to fix this + alignment.
Old Feb 10, 2012 | 12:48 PM
Cybermind's Avatar
Cybermind
Antisway bar bushings gets my vote.
To Shocks Squeaking?
