How do I remove
Old Feb 15, 2012 | 04:25 PM
David Shiel's Avatar
David Shiel
Default How do I remove
the larger flip-up plastic door covering the ash tray and lighter without doing any damage so I can replace it.
Dumb question , but I want to refinish it out of the car if possible.
Dave
Old Feb 15, 2012 | 04:35 PM
dougbfresh's Avatar
dougbfresh
Think you have to take the entire bezel off to get to the back side.
Old Feb 15, 2012 | 04:47 PM
David Shiel
Default I'll have to
look closely. Does the bezel snap off? I really should buy a manual, but I may not keep the C5 much longer, so I hate to invest in one.
Thanks,
Dave
Old Feb 15, 2012 | 05:22 PM
stevedun's Avatar
stevedun
Cruise-In 8-9-10-12 Veteran
Bezel does not just snap off. Screws in the console to slide it back and near ignition under cover plate also.
Old Feb 15, 2012 | 05:29 PM
Suthunman's Avatar
Suthunman
St. Jude Donor '14
Go to the MGW shifter website. There is a video that shows the procedure for removing the bezel.
Old Feb 15, 2012 | 07:22 PM
sfc rick's Avatar
sfc rick
NO SNAPS! It has to be removed from behind, so the bezel has to be removed completely. Once you have it off look carefully and you can see the two plastic rivets you can push out then remove the lid.
Old Feb 15, 2012 | 07:51 PM
m6 c5's Avatar
m6 c5
Yea its pretty straight forward on getting it out.
To How do I remove
