Replaced Oil Pressure Sensor
Old Feb 15, 2012 | 09:05 PM
BIGWILL_88's Avatar
BIGWILL_88
Default Replaced Oil Pressure Sensor
So I replaced my sensor that has not worked since I got the car in June. Now I am just wondering, should the pressure remain stable at one level or does it fluctuate because mine is fluctuating with the speed of the engine. Any advice is greatly appreciated.
Old Feb 15, 2012 | 09:54 PM
Rich98's Avatar
Rich98
It will fluctuate depending on temp, rpms and type of oil.
Old Feb 15, 2012 | 11:01 PM
DIXZ's Avatar
DIXZ
Perfectly normal!
Old Feb 16, 2012 | 09:10 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
As long as its a slower or progressive change with engine RPM, not a problem and totally normal. Now if its jumping wildly, then something is wrong with the wiring at the connector or a bad OPS.
Old Feb 16, 2012 | 10:12 AM
rebelheart's Avatar
rebelheart
Lower rpm = lower oil pressure,higher rpm = higher oil pressure,normal.
To Replaced Oil Pressure Sensor
