Wheel Bearings????
Old Feb 16, 2012 | 07:50 PM
vettegirl01's Avatar
vettegirl01
Default Wheel Bearings????
Kinda curious, i have a 2001 coupe for only four years, is it normal for both the rear wheel bearings to go out on it? The previous owner had 19 bmw m3 wheels (that I immediately replaced with the orginal stock 17 inches) on the car. Is this something a person will have to replace often?
Old Feb 16, 2012 | 07:54 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
gonna move this to C5 Tech where you can get some answers
Old Feb 16, 2012 | 08:08 PM
Zorlac's Avatar
Zorlac
My 01 vert had about 40K on it and I started hearing a moan from the right rear. I replaced the hub and it wasn't that bad of a job. It started after Vettes for Vets at Talladega. Maybe the speeds did it in. The left side isn't having any problems yet.
Old Feb 16, 2012 | 09:03 PM
jsbzoh6's Avatar
jsbzoh6
I had my right rear and right front go out on me within 1000 miles (car has 90k on it)
Old Feb 16, 2012 | 11:47 PM
RX-Ben's Avatar
RX-Ben
Unless you track the car, prob replace once every 100+k miles, maybe.
Old Feb 17, 2012 | 02:07 AM
1-USA's Avatar
1-USA
I had my Left Rear bearings go out at 9000 miles on my 2005!!!!!!!!!! I started to get a sing out of the rear that came on ever so slow.........I was thinking what the (^&$^*(….
Way to tell what side if you get this Sing from the rear.....on a open and straight road start to make sharp S turns...left, right, left , right at about 40 mph. The bad bearing will sing opposite of the turn or the side you are putting the torque onto.
Old Feb 17, 2012 | 09:52 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You can check the hubs to see if they need replacement and its simple to do. Jack the wheel, put a yard-stick or other straight edge on the outside of the tire, facing vertically across the tire/wheel...so your yardstick is essentially standing on the side of the tire. See if you can move the wheel horizontally from the bottom, watching the yardstick at the top. You are allowed a max deviation of 1/16th inch at the top of the wheel. If you've got more than that, time to get new ones.
Old Feb 18, 2012 | 10:22 AM
rws.1's Avatar
rws.1
145 k(s)miles on my '01 Vert. the right rear hub is just starting to make noise.
Old Feb 18, 2012 | 02:16 PM
RedC5's Avatar
RedC5
I think letting cars sit make the bearings to go faster.....happened to 2 GM cars with my grandparents <50k.
Old Feb 21, 2012 | 10:14 PM
Jet-Jock's Avatar
Jet-Jock
Wondering the same thing for my 70K '01 vert, I thought it was the spindle nut on the right rear, to a mid speed you hear a whop-whop sound. My brother and I were going to the store the other day and he commented on the sound I said do you hear it on your side or mine, his (right rear). Everything looks good back there, but I think it has to be a wheel bearing going. You also get clunking sounds from the same area when doing less than about 5mph in a parking lot.
I just read about the nordic lock bearing fastener kit. Definitely get those I think to install a new bearing.
Old Feb 21, 2012 | 10:24 PM
RX-Ben's Avatar
RX-Ben
Most likely a wheel bearing.
Not sure what the under 5mph is. If the splines are dry you might get a clicking when going from forward to reverse and vice versa.
Not likely to be problem with the nut.
Old Feb 21, 2012 | 10:33 PM
Jet-Jock's Avatar
Jet-Jock
Yeah I've serviced the spindles a few times. That settled the clunking sound when first starting out, but this is more of sound similar to a bad universal but I've inspected them all and nothing out of the ordinary. With so many reports of wheel bearings and the fact it is getting worst not better tends me that way as well.
Have to pull the FSM out and look at the procedure. Wonder what type of job this will be?
Is there a rule of thumb to replace both left and right sides when replacing just one?
Old Feb 21, 2012 | 10:39 PM
1-USA's Avatar
1-USA
"Clunking" noise as you are decribing it can be the rear end gear lube.
Look into Mobil 1 Synthetic LS / 75W-90 I remember that being a problem . Go on-line and you should find step by step photos on how to. I doubt this noise is a bearing issue.
Old Feb 21, 2012 | 10:41 PM
RX-Ben's Avatar
RX-Ben
Easy, just some wrenching.
Remove the axle nut (car on the ground is ideal).
jack up car, remove applicable wheel, brake caliper, bracket, disc, abs wire, e-brake cable
loosen upper bj bolt, separate joint
loosen tie rod, separate joint
rotate spindle away from car - the axle should come out of the diff but you might need to give it a tug
rotate spindle as necessary to remove axle
bearings come out w/T55 Torx
install is the same (make sure the abs sensor plug is oriented up as you removed it), but when installing the axle:
- insert splined end into diff (might need a stiff push to get it fully seated)
- lube the outboard splined end w/proper grease
- rotated the spindle and sharply end the end of the axle so that it fits into the wheel bearing splines
- bolt everything back together
This process avoid the tricky loosening/tightening of the lower ball joint.
Old Feb 21, 2012 | 10:45 PM
Jet-Jock's Avatar
Jet-Jock
Sorry I should have prefaced, I recently serviced the rear end and manual tranny fluid.
I've been working at this one for a while. I noticed the sound when I barely detected it, nobody else heard it, as time has gone on it is becoming very obvious even to my passengers.
Old May 7, 2012 | 11:47 PM
jdperk's Avatar
jdperk
I need to replace the pass side wheel hub due to noise and will change the other side just to have a matched set. I have questions on the process to change the hub. (2000 C5 Hardtop, 6-speed)
1. What size is the spindle nut?
2. Does the axle stay in the differencial and remove the hub end only?
3. The manual states the axle needs to be supported does this mean so that it doesn't slide out or it can't move or be damaged, what does it mean?
4. If the axle comes out of the differencial is it difficult to re-insert?
5. What are the torque specifications on the hub torque bolts and hub nut?
6. I was going to take the lower ball joint off but you imply there is an issue with this and taking the upper ball joint is prefered, why?
7. T55 torque what is this refering to a socket type torque bit, I used a 8mm allen wrench and it seemed to fit.
I got as far as the taking the brake rotor off when I realized I didn't have the correct socket for the hub nut so I had to put it back together. This doesn't look that hard just need a little more info for the right size tools and proper procedures.
Thanks in advance.
Old May 7, 2012 | 11:51 PM
02*C5's Avatar
02*C5
have a 02 with 126K on it and no issues at all.
To Wheel Bearings????
Old May 8, 2012 | 12:15 AM
Jet-Jock's Avatar
Jet-Jock
In this post (#2), is a link to download a PDF which should answer your questions jdperk.
Click Here C5 Wheel Bearing
I just had my rear bearings change OMG what a difference. I thought I also had tire/road noise, no that was all wheel bearings. Now it's super quiet and smooth. I was going to do the job myself but after looking at some tips, I decided to pay my dealer to swap them out for me. I had the new AC Delco parts I got at my discount. So it was reasonable five hours later I picked it up ready to go. (Normally, I do the knuckle busting )
Old May 8, 2012 | 12:36 AM
-98-z28-darkness-'s Avatar
-98-z28-darkness-
Jet-Jok thanks for the pdf file! will use it soon
just got alignment done last week and they told me that they felt a bit of play on a rear wheel.
probobly going with Timken, should be fine right?
Old May 8, 2012 | 12:50 AM
Jet-Jock's Avatar
Jet-Jock
I chose OEM AC-Delco. Check with Gene Culley for good discounted pricing.
There is a GM tool that makes the job easier on the ball joint and tie rod, if you are doing it yourself that tool would be real nice.
Here's where that originated, lots of good tips too what to watch out for.
Link here
