ls1 to ls6 intake problem
Old Feb 18, 2012 | 02:32 PM
tstrobl1's Avatar
tstrobl1
Default ls1 to ls6 intake problem
Ok, I know I'm not the sharpest knife in the drawer so please help. I installed an ls6 intake on my '98 ls1, do I need an ls6 fuel rail? The reason I ask is that the #1 injector seems to be at more of an angle and the fuel rail receptacle is straight. Of course #1 injector is leaking like crazy where it goes into the fuel rail. What's up with that?
Old Feb 18, 2012 | 04:07 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
PICTURE??? The LS1 and LS6 manifold are exactly the same hardware wise on top!!!. Should be a ONE for ONE swap and fit perfect.
BC
Old Feb 18, 2012 | 04:25 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
did you lube the O rings before pushing into the intake? you might need to replace them
Old Feb 18, 2012 | 06:26 PM
tstrobl1's Avatar
tstrobl1
Hmm...I installed new injectors with new o-rings and lubed them. Guess I'll pull it apart and check that. Bill, I'll get a pic up for you to see if I need more advice. Thanks.
Old Feb 18, 2012 | 07:19 PM
sfc rick's Avatar
sfc rick
Can't see how you ended up with that situation. They are the same as far as injectors are concerned. Please post a photo.
Old Feb 18, 2012 | 07:45 PM
tstrobl1's Avatar
tstrobl1
Notice how the fuel rail injector receptors are angled except for #1. It comes straight out of the rail or it almost looks like it is angled slightly the wrong way. Is it bent? I'm a very careful mechanic and I know this is exactly the way it came off the car but the angle that the injector goes into it won't allow it to seal. Nothing wrong with the o-ring that I can see. I never had a problem with my old ls1 intake with this rail or old injectors.
Old Feb 18, 2012 | 09:16 PM
tstrobl1's Avatar
tstrobl1
ttt
Old Feb 18, 2012 | 09:18 PM
VetteNoob's Avatar
VetteNoob
You bent the injector bung. This is what my rail looks like on #1.
Old Feb 18, 2012 | 09:45 PM
tstrobl1's Avatar
tstrobl1
Hey noob, thanks for the picture. Mine certainly is bent or maybe a manufacturing defect. I do know that I didn't bend it. Perhaps a previous owner or mechanic.
Old Feb 18, 2012 | 09:57 PM
rebelheart's Avatar
rebelheart
How ever it happened,it is bent.
Old Feb 18, 2012 | 10:02 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
just came in from the garage. my fuel rail is off because Im doing the swap too. good luck with the fix.
Old Feb 19, 2012 | 12:34 PM
sfc rick's Avatar
sfc rick
Yep, it's been bent!
Old Feb 19, 2012 | 12:37 PM
baxsom's Avatar
baxsom
yep you can definitely see the bent metal where the bung goes into the rail. Almost looks like it was dropped.
Old Feb 19, 2012 | 01:46 PM
tstrobl1's Avatar
tstrobl1
Success! I found a wood dowel that was just the right size to fit snugly into the bung and carefully put pressure on it and was able to get it back to the proper angle. Whew! Fuel rail is back on the car and no leaks. Thanks everyone for the input.
Old Feb 19, 2012 | 03:11 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
glad you got it fixed
To ls1 to ls6 intake problem
