Fast fuel rail installation
Old Feb 19, 2012 | 11:32 AM
dustysZ's Avatar
dustysZ
Default Fast fuel rail installation
Im getting ready to install a Fast 90/90 combo along with a set of Fast fuel rails. Have looked around for someone who has posted an install of fuel rails and cant seem to find one. One of the questions I have is. On some I see a cross over line on the front of the rails and others on the front and rear. Why? Whats the difference? So the question is who has a write up with pictures of this install. I like pictures.
Old Feb 24, 2012 | 10:33 PM
JeremiahsC5's Avatar
JeremiahsC5
bump
Old Feb 26, 2012 | 09:31 PM
"ZOSICKS"'s Avatar
"ZOSICKS"
Bump
Old Feb 26, 2012 | 10:57 PM
chevylad's Avatar
chevylad
I prefer to run a run a front and back line on fuel rails to give a better balance if the fuel pressure drops. I don't know if that actualy works, but I've had several aftermarket systems that came that way. On a C5 it's not so easy to put a rear line on the back of the driver side rail.
I looked to see what other guys were doing and there were some pretty high horspower supercharged cars running without a kind of balance line so I guess it must okay.
I have mine feeding in from the passenger side rear and run a distribution line from the front of each rail with a tap off the front for a fuel pressure transducer.
When I install my supercharger I plan on putting a return line in the front tieing the two rails together.
Old Feb 27, 2012 | 02:09 PM
JeremiahsC5
I guess my new set up would be considered high horsepower. 800rwhp. I am searching for more info on this topic. As of now I do not want to cut the fire wall. I am looking for the best way to supply and return my fast fuel rails. I am planning on running a supply line to the back of the passenger fuel rail -6. And then jumping the passenger side to the drivers side in the front. Then tee off the drivers side front rail and run that line to my regulator and on to the return line. I know this could be reversed and supplied to the front and returned off the back. Anyone have an comments on this setup. I am open to sugestion.
Old Feb 27, 2012 | 05:12 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I did not install the Fast Fuel rails, but I have a full write up on my fast 92 install on my web site. Full pics, parts needed, torque specs, etc...
www.ToqueZ06.com
Toque
Old Feb 27, 2012 | 06:29 PM
Rob Petyo's Avatar
Rob Petyo
Originally Posted by dustysZ
I like pictures.
mine is a '98' with a return fuel line.
Old Feb 27, 2012 | 07:59 PM
JeremiahsC5
What fittings are you running in the back of your rails Hot Wheels? Did you cut your fire wall on the drivers side?
Old Feb 27, 2012 | 09:00 PM
Rob Petyo's Avatar
Rob Petyo
a little bit
To Fast fuel rail installation
