Secondary Air Injection Pump
Old Feb 19, 2012 | 03:41 PM
Bruce Schilling's Avatar
Bruce Schilling
5th Gear
Default Secondary Air Injection Pump
Can anyone tell me how to gain access to the air pump. I know its under the Drivers side headlight, but how do you get to it?
Old Feb 19, 2012 | 04:38 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Jack up the front of the car and remove the close out panel under the front facia. Once it off its easy to find:
Old Mar 4, 2012 | 11:52 AM
Bruce Schilling
5th Gear
Thank You Bill
As you have probably read I’ am getting the P1416 code, I did the clean out method you suggested and verified the valve is functioning properly by using air. Air does get past the valve and the valve does prevent air form getting back to the pump. What I noticed was that the air pump is not coming on at cold start. Now I want to check the Pump and control circuit. Do you know of a way I can turn on / power the pump independently? I don’t have a schematic of the control circuit and would greatly appreciate any help.
Thanks in advance
Bruce
Old Mar 4, 2012 | 12:10 PM
sunchaser73's Avatar
sunchaser73
Bruce...pm me your email address and I will send you some circuit drawings and the DTc guide for P1416...
Old Mar 4, 2012 | 01:25 PM
sunchaser73
Bruce...email sent with info...
Old Mar 4, 2012 | 01:27 PM
Bruce Schilling
5th Gear
Thank You
To Secondary Air Injection Pump
