Oil Change
Old May 14, 2002 | 06:58 PM
QWKAZEL's Avatar
QWKAZEL
Cruise-In III Veteran
Default Oil Change
Took the car to the dealer for the first oil change(3000) and the Oil Life reading went back up to 100%, well I went to Jiffy Loob for the 6000 and the Oil Life reading stayed at 87%...is there something the dealer did that JL didn't? Is there some magic switch that put the reading back to 100%? :confused:
Old May 14, 2002 | 07:10 PM
PeteyPete's Avatar
PeteyPete
Default Re: Oil Change (QWKAZEL)
you have to reset it yourself...there are a two ways that i know, i just turn the ignition w/o starting it and press the gas pedal three times, and it should reset itself.
Old May 14, 2002 | 07:15 PM
JerryL's Avatar
JerryL
Cruise-In II Veteran
Default Re: Oil Change (PeteyPete)
Select the oil life remaining on your DIC and hold the reset button for a few seconds.
Old May 14, 2002 | 07:19 PM
QWKAZEL's Avatar
QWKAZEL
c'mon man.......should i press in the cig lighter too :lol:
Old May 14, 2002 | 07:20 PM
PeteyPete's Avatar
PeteyPete
It works, try it.
And after if works, get on your knees and beg for ever doubting my omniscience. :p:
[Modified by PeteyPete, 11:24 PM 5/14/2002]
Old May 14, 2002 | 07:28 PM
QWKAZEL's Avatar
QWKAZEL
Default Re: Oil Change (JerryL)
I went this route....it's back to 100%. I'll try the other way next time. Thanks guys :yesnod:
Old May 14, 2002 | 07:30 PM
QWKAZEL's Avatar
QWKAZEL
It works, try it.
I'll keep that in mind the next time I get the oil changed
Old May 14, 2002 | 10:50 PM
docman's Avatar
docman
My owners manual for my 2002 says to turn the key on without starting the engine. Press the TRIP button so the OIL LIFE percentage is displayed. Press RESET and hold for two seconds. The OIL LIFE REMAIN 100% will appear. He is right, you have to do that yourself. The Jiffy Lube people probably don't have a clue how to reset it.
Old May 14, 2002 | 10:59 PM
QWKAZEL's Avatar
QWKAZEL
Default Re: Oil Change (docman)
If you read earlier, I went with what you wrote and said it was back to 100%
To Oil Change
